Neurochrome HP-1
m1ts0s
News poster
HP-1: Ultra-High End Headphone Amp
The Neurochrome HP-1 is an ultra-high end headphone amplifier capable of producing up to 3 W into a 20 Ω load at vanishingly low distortion. The HP-1 will drive even the most challenging headphones with the utmost fidelity and natural sonic profile. It is designed to be as close to a straight wire with gain as technically possible. In addition to providing the ultimate technical performance, the HP-1 also provides peace of mind as it contains advanced protection circuitry which will protect your headphones in case of various fault conditions.
Key Features
  • Fully optimized 4-layer circuit board.
  • Total harmonic distortion: 0.000032 % (200 mW, 300 Ω).
  • Total harmonic distortion: 0.000050 % (200 mW, 32 Ω).
  • Total integrated output noise: 1.0 µV RMS (A-weighted, 20 Hz – 20 kHz).
  • Output power: 3.0 W (32 Ω).
  • Output power: 450 mW (300 Ω).
  • Gain selectable (+6, +12, +20 dB) by front panel switch to accommodate a wide range of sources, including smartphones, tablets, DACs, and CD players.
  • 1/4″ phone and 4-pin XLR output connectors.
  • Balanced (XLR) and unbalanced (RCA) inputs.
  • ±0.1 % tolerance Susumu RG-series resistors used in critical parts of the circuit to ensure the best possible performance.
  • All signal switching is accomplished using relays with gold plated switch contacts.
  • ALPS RK097 volume control potentiometer.
  • Well filtered switching power supplies followed by onboard low noise linear post-regulators ensuring the highest power supply performance.
  • Protection against DC voltage on the amplifier output.
  • Integrated mains soft start and 320 Joule surge suppressor.
  • ON indicator emitting a subtle and pleasant blue glow.
  • International mains voltage compliant (85 – 264 VAC @ 47 – 440 Hz).
  • All aluminum chassis made in Canada.
HP-1 unpopulated PCB with RCA connectors and volume knob included. $250
Fully assembled and tested circuit board. $1,199
Fully assembled and tested HP-1 headphone amplifier. Covered against defects in parts and workmanship by a one-year warranty from the date of purchase. $1,599
http://www.neurochrome.com/product/hp-1-ultra-high-end-headphone-amp/
Μετρήσεις: http://www.neurochrome.com/hp-1-ultra-high-end-headphone-amp/
Key Features
Καλό φαίνεται αλλά πως να γλιτώσεις τελωνείο είναι το θέμα διότι μπαίνοντας στην κατηγορία 2000+ υπάρχουν πιο προσβάσιμες ανταγωνιστικές προτάσεις. Ίσως η αγορά της πλακέτας μόνο να δουλέψει. Και όλα αυτά χωρίς δυνατότητα δοκιμής.
Βασίλειος
