Nextbit Robin
m1ts0s
News poster
It’s time to think about the cloud in a whole new way.
Unlike anything before it, Robin has the cloud integrated right into Android OS, and its perfectly tuned hardware is optimized to take every advantage of it.
That means Robin is always prepared. Whenever it’s plugged in and on Wi-Fi, it backs up your apps and photos. And when you need space, it archives the things you use least, so you always have space for what you want most.
There’s always a thumbnail for everything archived, and with one click it’s back on Robin. You don't have to log back in and you never lose your data.
Simply bold.
Robin is designed to feel effortless — reducing clutter and increasing usability.
The placement of everything is thoughtfully considered. Every port, button and sensor feels intuitive and harmonious. Its modern design separates Robin from the crowd. With Robin, you stand out.
Intelligently secure.
Security is critical to us, and we know it is to you too.
Robin’s fingerprint identity sensor secures it effortlessly. Press the power key, leave your finger there for a split second and Robin is unlocked. No more complicated swiping or passwords.
Nextbit takes your data security just as seriously when it’s not on Robin. It is securely transmitted and stored encrypted on our servers. And we provide two factor authentication with Google.
Smarter specs.
Robin runs on a premium Qualcomm® Snapdragon™808 processor. Its battery is engineered for efficiency to get you through the day, and its camera is optimized for taking incredible photos and videos.
Display
  • 5.2” IPS LCD 1080p, Gorilla Glass 4
Battery
  • 2680 mAh
Camera
  • 13MP rear–facing with phase detection autofocus, dual tone flash
  • 5MP front–facing
Processor
  • CPU: Qualcomm® Snapdragon™ 808
  • Memory: 3GB RAM / 32 GB onboard / 100 GB online
Additional Specs
  • Dual front facing stereo speakers
  • Fingerprint sensor
  • NFC
  • Quick charging
  • Bluetooth 4.0 LE
  • GPS enabled
  • WiFi A/B/G/N/AC
No barriers.
Robin comes with an unlocked SIM, so you can choose the right carrier for you. And because we think what you run should be up to you too, we’ve made it as easy as possible for you to customize Robin. Its unlocked bootloader and open source drivers make it easy to load CyanogenMod or any other ROM you want and Robin will still be under warranty.
https://nextbit.com/
Gojakla
Αρχαιολάγνος πιουριτανίστας
Το λεπόν, ξεθάβω το νήμα διότι μάλλον είμαι απο τους ελάχιστους στο Ελλαδιστάν που το έχει...
Το τηλέφωνο πραγματοποιεί όσα υπόσχεται... δλδς είναι γρήγορο (κατά 98% stock android), έχει αυτή την παπαριά στο cloud (παπαριά όχι γιατί δεν δουλεύει αλλά γιατί πόσοι απο εμάς θα "σωθούν" ή θα χρησιμοποιήσουν το option των +100gb στο cloud? - πάντως ωραίο feature), η μπαταρία του βγάζει το 24ωρο, ωραιότατη οθόνη, μια χαρά κάμερα, nfc, fingerprint sensor, dual stereo speakers... μπλα μπλα μπλα...
Στα + το "ιδιαίτερο" design. Πράγμα που εμένα με έκανε να το επιλέξω.
Ξεχωρίζει απο το σωρό και με κάνει να νοιώθω καταπληκτικά ιδιαίτερος και προικισμένος.
Το ακουμπάω στο τραπέζι και το κεφαλογυρισόμετρο πιάνει 9ρια... Κάτι S7 και κάτι iPhone τα φτύνει στα μούτρα. :D
Το άλλο καλό που έχει είναι πως δεν χρειάζεται να δώσεις ένα μηνιάτικο.
Στην πόρτα σας με 299 ντολαρς.
Σημαντική σημείωσης προς αποφυγή παρεξηγήσεων:
Το τηλέφωνο αποστέλεται με Fedex.
Ναι, καλά το φαντάζεστε, μόλις έρθει στο Ελλαδιστάν θα λάβετε ένα τηλεφώνημα απο μια ευγενική κυριούλα της Fedex και θα σας ζητήσει να εκτελωνίσετε το προϊόν.
Γελάστε. ΧΑΧΑΧΧΑΧ.
Και εξηγείστε στην μανταμίτσα (που δεν φταίει και πουθενά δλδς) ότι στο ποσό που πληρώσατε, ναι τα 299ντολαρς, ΣΥΜΠΕΡΙΛΑΜΒΑΝΟΝΤΑΙ ΦΟΡΟΙ ΚΑΙ ΜΕΤΑΦΟΡΙΚΑ.
Η αγπαητή μας κυριούλα θα σας ευχαριστήσει για την ενημέρωση και θα σας πεί πως θα επικοινωνήσει με τον αποστολέα για τα καθέκαστα...
Περνάει καμιά βδομαδούλα που σας τρώει ο κώλος σας να ξέρετε ότι είναι Ελλάδα αλλα όχι στην κωλότσεπή σας, εώς το 2ο τηλεφώνημα της ευγεμικής μαντάμ που σας ανακοινώνει πως όλα καλά με τον εκτελωνισμό απλώς θα πρέπει να συμπληρώσετε κάποια διαδικαστική χαρτούρα (μια δήλωση που αποστέλετε υπογεγραμμένη μέσω email και μια ηλεκτρονική φόρμα που συμπληρώνετε).
Μετά απο αυτό τον ΑΝΩΔΥΝΟ γολγοθά και αφού αποστείλετε τα απαραίτητα, την μεθεπόμενη ημέρα το έχετε στα χέρια σας!
:party::party::party:
Gojakla
Το πήραν όλοι οι μετροσεξουαλ και παρεϊντ... το ίδιο πήρε και ένας φίλος μου και του κρεμάσαμε κουδούνια... :laugh: :laugh: :laugh:
Έτσι, ένας άντρακλας μηχανόβγιος (και όχι κουτάκιας ή όπως τα λέτε) δεν μπορεί να έχει φυστικί. Αυτά είναι για 'μάς τους λεμέδες. :D
Μπας και το πουλάει η φίλη σου; :p
JGmag
