Nobsound® Little Bear P8 SEPP Pure valve Tube Headphone
Power Amplifier Pre-AMP metal Stereo HIFI audio Preamplifier
Αριστος ενισχυτής ακουστικών αλλά και σαν προενισχυτής έπαιξε άψογα και με τρανζίστορ και με λάμπες.
6N3+6N5P Tube Headphone amp Little bear p8 Class A amp
Toroidal transformer version ,With a circular black shield,Overall appearance.
This is a headphone amplifier ,Only suitable to connect various headset .( 20-500 ohm best.)
can use as a pre-amplifier .Unplug the headphones, automatic conversion RCA output .But not directly connected to the speaker .Because the power is not able to push the speakers.(Output Power: 1.2W ).
Specifications:
Impedance: 20 to 500 ohms .
Output Power: 1.2W .
Output Frequency Response: 10Hz to 95kHz -3dB .
SNR:> 109dB "A" - wtd .
Harmonic distortion: <0.8% 10Hz to 20kHz .
Input voltage: 220VAC 50 / 60Hz .
Net Weight: 2.8kg .
ΤΙΜΗ 100 ΕΥΡΩ.
ΘΕΣΣΑΛΟΝΙΚΗ ΚΑΤΑ ΠΡΟΤΙΜΗΣΗ ΑΛΛΑ ΜΕΤΑ ΑΠΟ ΚΑΤΑΘΕΣΗ ΑΠΟΣΤΕΛΩ ΠΑΝΤΟΥ.
Specifications:
Net Weight: 2.8kg .
ΤΙΜΗ 100 ΕΥΡΩ.
