Nomad Audio RPD Open Baffle
Κώστας Φ.
Με καμπίνα από...bamboo!
Seas Excel μεσαία και ψηλά (dipole coaxial driver), Peerless στις χαμηλές.
Μερικά ακόμη χαρακτηριστικά:
Many finish options, bi/tri wiring, external crossover, digital equalization also available at a very reasonable surcharge.
Στα $4,500 το ζευγάρι.
If you think inside the box, there are myriad options available in this price range. The FJ OMs remain my favorite pick for their unique combination of lushness and transparency. If however you want to transcend the box with its ubiquitous colorations, Nomad Audio's Ronins are a very easy recommendation, so easy in fact that I am buying this pair as my new reference speakers, to put my money where my pen is; and more importantly, to enjoy this performance every day.
Application conditions: Won't mate happily with all amplifiers and require high current capacity into 2/4 ohms to get their 10" woofers to sing but also require a very refined but rich amplifier midrange.
Final comments & suggestions: If you favor tubes, consider the active version with higher impedance throughout and better bass control; it should be the most versatile of all RPD versions. The RPDs are also ideal for the old recipe of 'tube on top, solid state at the bottom' if you are willing to handle the added complexity. If you want to add a sub, pick it lean, lightning-fast and detailed (think Zu Method, Martin Logan Descent or REL Q108 ), anything else will smear the crystal-clear midrange.
Full Review: 6moons.com
Nikos67
