NuForce P-8 Preamplifier
Κώστας Φ.
Cost: $1095 (MSRP)
"The P-8 has been the first NuForce preamplifier; it is not a very recent product, but its price tag makes it one of the few preamplifiers eligible for a mid priced system. So I was really interested in verifying the level of this unit, as not always power amplifier producers are able to achieve the same results with pre-amplifiers.
Conclusion
So you might think we have here a hyper detailed, unforgiving preamplifier, with a not perfectly smooth sound. But is this the correct point of view? Not at all. There are a few important elements to take into consideration.
First of all, the unit has been compared with very high quality tube preamplifiers. In absolute terms, very few units can go through such a test without showing any flaw. In particular the sound is only very slightly less liquid and smooth than the references, which is in my view already a great success.
Secondly, the unit has a few areas (transparency and precision, in particular) in which its performance is better than the references.
Finally, if you just compare P-8 tag price with any decent preamplifier on the [Italian] market, you'll realize that, apart a few products of minor brands, this unit is probably the less expensive available. So, you simply should not expect it to be as good as the best units, costing ten or more times.
Actually, the P-8 excesses were barely perceivable, even though the unit has been tested in a very high quality system. I would really be very surprised if they should prove perceivable in a economically balanced system.
However, it approximates or makes better than the reference units in some areas, which makes it a very good unit, independently from its price tag, and a great bargain if you consider it.
So before buying a new preamp you are strongly suggested to give P-8 a chance, listening to it as long as possible to get used to its sound. At the end, perhaps you will decide that this is not the ideal pre-amp for you, but for sure it will open your eyes about what you should expect for the money."
Full Review: TNT-Audio
deleted user 10898
το ιδιο μποαρντ εχει για το σταδιο της προενισχυσης ο ολοκληρωμενος ia7-v2. πληρης διαφανεια, απουσια χρωματισμων και ο θεος βοηθος για τα συνοδα...
Κώστας Φ.
Εγώ περιμένω να δω τη νέα (ακριβή) σειρά της NuForce. :happy_2:
Σύμφωνα με άνθρωπο της εταιρείας: "In late 2008, there will be a super expensive line coming."
deleted user 10898
α εισαι χαι εντ εσυ... :happy_4:
και εγω τους περιμενω αλλα μονο για λογους συγκρισης...
Κώστας Φ.
Να λείπουν οι χαρακτηρισμοί!
Εγώ τους περιμένω διότι, πολύ απλά, μου αρέσει να παρακολουθώ τις εξελίξεις στους Class D.
Άσε που μπορεί να αρχίσει κανείς να "σκοτώνει" τους "παλιούς"... :happy_9:
melina
Cargo 200
Είσαι σίγουρος? Υπονοείς επίσης ότι λόγω ίδιου board κάνει και ακριβώς τα ίδια πράγματα στον ολοκληρωμένο?...ο οποίος έχει και έξοδο Pre-out configurable αν θες.
deleted user 10898
"Our P-8 is a very good entry level preamp (IA-7V2 preamp circuit comes from P-8 )."
σε εισαγωγικα γιατι δεν το λεω εγω αλλα ο Jason Lim CEO της Nuforce...
:happy_6:
Σε συνέχεια αυτού θα ήθελα να ρωτήσω το εξής :
Εχω τον IA7 v2 και εχω πάθει πλάκα με το πως παίζει αυτό το μηχανάκι που μόλις αγόρασα και τους Referenve 9V2 και πλέον παίζω με προενισχυτή τον ολοκληρωμένο αφού σετάρισα την 4η RCA είσοδο ως pre -out (ευκολη ρυθμιση ,περιγράφεται στο manual του ολοκληρωμένου ).
Γιατί συνεχίζει και ανεβάζει τόσο υψηλή θερμοκρασία ο ολοκληρωμένος αφού υποτίθεται οτι δουλεύει μόνο το board της προενίσχυσης ?
Επιπλέον αναγράφεται στο manual οτι στην παραπάνω περίπτωση το τμήμα της τελικής ενίσχυσης απενεργοποιείται (booster off) όταν δεν υπάρχουν ηχεία συνδεδεμένα.
Ελπίζω να μην κάνω κάτι λάθος .
Κατα τα άλλα παίζει απίστευτα .....
deleted user 10898
γιατι η ψυξη του γινεται απο το επανω μερος του κουτιου.
μη σε απασχολει...
IA-7 V2 internal amplifier board has a different heat sink orientation and more efficient heat dissipation than previous generation V1 board. It is also designed to conduct heat directly to the top cover of IA-7 instead of the bottom chassis for better heat dissipation. Therefore the cover of IA-7 V2 will appear to be hotter than previous version of IA-7 but the objective is to provide long term reliability of the internal components. After prolong use, IA-7 V2 top cover's temperature could reach 54 degree C.
Νικος
μη σε απασχολει...
Νικος
....thanx for info
Τώρα είδα το πίσω μέρος του IA7 v1 σε ένα review και είχε διακοπτάκι booster off για να κλείνει το τμημα τελικής ενίσχυσης και να λειτουργεί ως pre amp, το οποίο δεν υπάρχει στην V2 έκδοση ....μάλλον το τμήμα τελικής ενισχυσης δεν λειτουργεί στην V2 αυτόματα όταν δεν υπάρχει φορτίο συνδεδεμένο στις εξόδους των ηχείων .....
Τον φέρνει ο Music Lover....δεν γνωρίζω ακριβώς τιμή , αλλα επειδή έχω ήδη τον ολοκληρωμένο και τους Ref9 πρεπει να έχει κοντά στο χιλιαρικο.
Atoll
