NuForce P-9 Preamplifier
Κώστας Φ.
Price: $3150 USD.
Warranty: Three years parts and labor.
"Features
The NuForce P-9 "places all noisy circuitry (three separate power supplies and the microprocessor control logic) in a separate chassis.… The other chassis contains only analog circuitry, including a continuous ALPS volume potentiometer. The audio signal passes only through the analog chassis, safely isolated from noise."
Bottom line
A preamplifier has a tough job. At a minimum, it must take low-level signals, pass them through a selector switch and volume control, and then through one or more gain stages to produce a signal that can drive interconnects and a power amplifier, all without theoretically adding any sound of its own. Because the level of incoming signals is low (often only a fraction of a volt), a preamp must also be extremely quiet; any noise it creates will be amplified along with the signal. The volume control is also a big factor. Junky volume controls have been known to degrade a preamp’s sound. Ditto poor selector switches.
Well, if the function of a line stage is to pass the signal through without changing anything except its level, then the NuForce P-9 fills the bill. The P-9’s transparency is exceptional. In retrospect, this preamp's extremely low noise, colorful tonal palette, and notable dynamic prowess were really features of the products I listened to with it. That's transparency. During the P-9's stay in my system, I never once wished I was listening to a tube line stage, and I haven't been able to say that about many solid-state preamps.
Demian Martin and the folks at NuForce have produced a line-stage preamp worthy of the company's distinguished amps -- and really any amp with which you'll pair it. The P-9 is a solid-state line-stage preamp that even a confirmed tube dude like me could live with."
Full Review: SoundStage!
Mετρήσεις: Click
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
NuForce P-9 Stereo Preamplifier
Specifications:
● Solid State Stereo (Two-Channel); Two
Box Design - Power Supply and Control
Circuitry in One Chassis and Analog
Circuitry in Second Chassis
● Inputs: Five Sets RCA including One
Bypass
● MFR: 20 Hz - 20 kHz, + 0.02 dB, - 0 dB
● THD+N: 0.0004%
● Maximum Output: 7 Volts
● Input Impedance: 10 kOhms
● Output Impedance: 100 Ohms
● Remote Control
● Dimensions (Each Chassis): 1.75" H x
8.5" W x 16" D
● Weight: 13 Pounds Total
● MSRP: $3,150 USA
"...At $3,150 the NuForce P-9 is a stunner in the performance department, if not in its looks. It is manufactured in Asia, and if anyone still thinks that means "not so good", it is time for them to wake up and listen to the music. Those days are gone. Now you can have truly high end quality that doesn't break the bank.."
http://www.hometheaterhifi.com/volume_14_3/nuforce-p9-preamplifier-8-2007-part-1.html
Κώστας Φ.
Απάντηση: NuForce P-9 Stereo Preamplifier
Πάρκαρε εδώ, μάστορα! :mrgreen:
Περιμένω με αγωνία κανένα εκτενές review των Ver.2 τελικών τους...
Grigoris1966
