Olive’s OPUS Nº4
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Custom-built in the USA The OPUS is designed and custom built in California, USA, building on the innovative energy of the Silicon Valley and the music passion of the city of San Francisco. Each OPUS Nº4 is built to order, guaranteeing you the latest in technology at the best price possible. And it gives us the opportunity to quickly respond to the many special requests that our customers have. After all, each OPUS becomes as unique as your taste for music.
State of the art technology platform & high-speed processor. Ample processing power for multi-tasking.
Simultaneous recording of and listening to CDs.
Flawless encoding and decoding of lossless audio format.
Fast management and access to extensive music libraries.
Supports music playback in 24-bit/96khz, 250 times the resolution of CD music!
Color LCD 4.3" wide-aspect ratio, high-resolution touch-screen
(480 x 272 pixels) Superior color and image quality.
See more of your music information, and browse by album artwork.
Color-coded and touch-screen navigation lets you find your music fast.
Hard Drive Ultra-quiet 320, 500, 750 and 1,000 GB drives, cushioned in 8 layers of noise cancelling padding Holds up to 3,000 CDs in lossless quality.
Design Energy-efficient design and fine-grade, heat dissipating aluminum enclosure. Passive cooling concept without noisy fan.
Ultra-quiet operations. Be the only one whistling to your music.
CD mechanism Panasonic CD-R/RW High fidelity CD audio playback.
Networking Wired Gigabit Ethernet Fast bandwidth for seamless multi-room audio streaming
Wireless 54 Mbit/s (802.11g)
Encryption WEP + WPA, 64- and 128-bit Ultimate security.
Audio Outputs Analog 1x RCA Wide variety of high-quality audio outputs to connect to your stereo system.
Digital 1x digital output S/P DIF optical Toslink, 1x digital output S/P DIF coaxial cinch
Audio Formats WAV, FLAC, MP3 (128 to 320 bit/s). Maximum compatibility with today's digital music formats.
Other Ports 1x USB 1.1/2.0 Backup your music library to an external hard drive.
Connect and play music from your Apple® iPod™. Access music on your iPod™ anywhere within your home with the MELODY No2 (optionally available).
Color Silver or Black Fits perfectly to your stereo system.
Measurements Width 17.13"
Height 3.35"
Depth 11.42"
Weight 13.2 lb
Box includes 1x Olive OPUS, Quick Startup Guide, remote control w/ battery, CD with recovery software, power cord, RCA cable.
http://www.olive.us/products/opus4.html?PHPSESSID=2543f723dfae4d652771df471488ec02
Απο 1499$
Ομορφούλι.
Σιγά σιγά αντίστοιχα μηχανάκια θα βγάζει και η κουφή/κουτσή Μαρία….
Τουλάχιστον αυτοί το έκαναν ομορφούλι.
Το αναλογικό κομμάτι του δεν νομίζω να είναι τίποτα περισσότερο από απλή κουτσή κάρτα ήχου.
Σαν τρανσπορ φαίνεται βολικό. Αν και θα μπορούσε να έχει και TV out ώστε να είναι πιο εύκολο το navigation.
Πληροφορίες για το ripping δεν δίνουν και εκεί πιθανά να πάσχει (pregap οεο?) όπως πολλά αντίστοιχα.
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Olive’s OPUS Nº4
H Olive είναι ίσως η πρώτη εταιρία παγκοσμίως που κυκλοφόρησε ένα τέτοιο μηχάνημα. Το παρήγορο είναι ότι
α) συνεχίζει ακάθεκτη
β) οι τιμές της πέφτουν συνεχώς.
Τα $1500 είναι περίπου 1000€, όσο ένα μεσαίας κατηγορίας cd player. Ευχαρίστως θα τα έδινα στο Οlive, αλλά για CD player δεν είμαι σίγουρος αν θα τα έδινα. Μακάρι να βρεθεί κάποιος αντιπρόσωπος για την Ελλάδα (νομίζω υπάρχει στην Γερμανία).
http://www.olive.us/products/opus4_overview.html
Εάν κάποιος δε χρειάζεται pc/mac για άλλους λόγους, αυτό το μηχανάκι νομίζω ότι είναι καλό.
Υπάρχει κάτι άλλο σε αυτή τη κατηγορία τιμής, με αυτές τις δυνατότητες ?
opanamas
