OMEGA speaker systems
Welcome to Omega Speaker Systems. Our goal is to engineer and manufacture loudspeakers which faithfully recreates music the way it was intended. A high efficiency, amplifier friendly (especially S. E. T.), crossoverless loudspeaker offers more detail, speed, dynamics, and musical involvement. Our line is designed to do just that. We also wanted to make it affordable. From $399 pair for the standard models including your choice of 7 finishes, it is considerably less expensive than most full range crossoverless loudspeakers on the market.
To keep costs down and to make our products very affordable we decided manufacture all cabinets in house. Avoiding outside costs as much as possible saves us and you money. We wanted to make purchasing as easy as possible by offering a 30 day in home trial to audition our loudspeakers with your electronics and in your room. If dealer is not in your area. We back all our products with a 10 year parts and labor guaranty.
ΜΕΡΙΚΑ ΜΟΝΤΕΛΑ:
Grande 8 - Grande 8 R
Type : Ported Single Driver stand/shelf mount
Frequency response : 46-20KHz
Sensitivity : 96dB at 8 ohms
Power requirement : as little as 1.5 watts
Driver : Full range 8” paper dual cone Fostex with rubber impregnated surround, alloy chassis and fully shielded
3 inch single port
Cross-over : None
Terminals : Standard multiway gold plated binding posts. R : Cardas Patented Copper Posts and Omega "R" internal wiring
Cabinet : heavily braced softwood MDF and adhered with polyurethane glues. R model includes R compound lining of interior walls.
Wood finishes : Cherry, Maple, Sapele, and Walnut with solid hardwood corners
Laminates : Black and Red Parisian Maple gloss Pearl, Blue Artic Pearl Gloss
Warranty 10 year parts and labor for workmanship and defects
Dimensions : 20” H x 9.5”W x 13”
Weight : 35 pounds each
Price :
Grande 8 : $999 per pair
Grande 8R : $1399 per pair
TS33
Type : Ported Front Firing Dual Single Drivers stand/shelf mount
Frequency response : 56-20KHz
Sensitivity : 96dB at 4 ohm
Switchable 4/16 ohm impedance
Driver :Twin Full range 4” paper cone Fostex with rubber impregnated surround, alloy chassis and fully shielded
Cross-over : None
Terminals : Standard multiway gold plated binding posts. Twin Sets and jumpers
Dimensions : 18” H x 8.5”W x 13”D
Weight : 30 pounds each
Price :
TS33 : $849 per pair
Super 3 - Super 3 R
Frequency response : 58-20KHz
Sensitivity : 93dB at 8 ohms
Power requirement : as little as 2 watts
Driver : Full range 4.5” paper dual cone Fostex with rubber impregnated surround, alloy chassis and fully shielded
2" single port
Cross-over : None
Terminals : Standard multiway gold plated binding posts. R : Cardas Patented Copper posts and Omega "R" internal wiring
Dimensions : 15” H x 12”W x 7.5”D
Weight : 20 pounds each
Price :
Super 3 : $549 per pair
Super 3R : $749 per pair
Ωραία πράγματα !
Μου αρέσουν ΠΟΛΥ ! Και πάνε παρέα και με ολιγόβατες λαμπίτσες..
(Γιάννη τα συγχαρητήριά μου για την φοβερή δουλειά που κάνεις στο site)
nikpapageo
