Omicron audio
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Marble Turntable
Marble and Crystal
Excellent sound and quality
that last forever
With 27Kg total mass the 30mm marble creates a heavy and fast turntable capable of supporting any High End tonearm
24 pole ultra silent AC Synchronous motor
Teflon coated stainless steel and bronze central bearing
Retro Turntable
Lacquered wood and crystal
With 8 Kg total mass this turntable is an inexpensive solution with a light and clear sound
Plywood is used for its combination of sound properties and high durability
Wave Turntale
Wood with Crystal
or Aluminum Plinth
A 7 to 8 Kg total mass turntable with the plinth mounted either directly or on a spring supported Sub Chassis
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Marble Amplifier
A handcrafted all tube integrated
12x6550, 6SL7, 6SN7 tubes
ECC88 phono preamp
All Svetlana / Sovtek tubes
Hammond output transformers
2x100 Watts RMS ultralinear
2x75 Watts triode mode
Output power
100WRMS, 30Hz to 16kHz into 8W
Distortion
0.6% @ 100WRMS, 1kHz
Load impedance
8W
Frequency response
20Hz-20kHz @ +/-0.5dB
SNR (unweighted)
75dB (CD input)
Equivalent input noise
(phono unweighted) 0.6mV
Wood and Aluminum
Tube Pre-Aplmplfier
Mosfet Final-Amplifier
2 X 100W RMS
Gianni Tab
