Oppo BDP-101C1 Blu-Ray Disc Transport
Nelsy
Ιεράπετρα
...Universal disc format support
Upscaling to Ultra HD (4K) resolution
VRS® ClearView™ video processing
Modular design for custom integration
Advanced Features
  • Universal disc format support including Blu-ray, Blu-ray 3D, DVD, DVD-Audio, Super Audio CD, CD, HDCD and more
  • Upscaling to Ultra HD (4K) resolution
  • VRS® (Video Reference Series) ClearView™ video processing
  • Dolby® TrueHD and Dolby Digital Plus decoding
  • DTS-HD Master Audio™ decoding
  • Bitstream output compatible with Dolby Atmos and DTS-X
  • Three USB ports for playback of media files2 (AVCHD, MKV, AVI, MP4, WAV, FLAC, APE, DSD, etc.)
  • Ethernet port for BD-Live, firmware upgrade and home network media file playback
  • True 24p™ video for Blu-ray encoded in 24Hz frame rate and optional conversion of DVD to 24p
  • Multiple zoom modes
  • Advanced picture control including video smoothing, detail and edge enhancement
  • Premium 32-bit audio DAC by AKM
  • Optical and coaxial digital audio outputs
  • Rigid steel chassis and center mounted disc loader with motion balance and vibration isolating mechanisms
  • Back-lit remote control
Custom Integration Features
  • Versatile modular design with many customized options
  • One or two HDMI outputs via the additional HDMI output module
  • Optional HDBaseT output module for long cable runs
  • Stereo or optional 7.1ch analog audio output module
  • Optional rack mount kit
  • Large front panel buttons with finger guards
  • RS232 and IP control for system integration
  • Switchable rear IR sensor for a clean IR blaster/emitter installation
  • HDMI CEC (Consumer Electronics Control)
  • Three customizable picture adjustment presets
  • Settings can be locked to prevent inadvertent changes
Specifications
Designs and specifications are subject to change without notice.
Disc Types BD-Video, Blu-ray 3D, DVD-Video, DVD-Audio, AVCHD, SACD, CD, HDCD, Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE
BD Profile BD-ROM Version 2.5 Profile 5 (also compatible with Profile 1 Version 1.0 and 1.1)
Output Analog Audio: stereo / 5.1ch / 7.1ch
Coaxial/Optical Audio: up to 2ch/192kHz PCM, Dolby Digital, DTS.
HDMI Audio: up to 7.1ch/192kHz PCM, up to 5.1ch DSD, bitstream.
HDMI Video: 480i/480p/576i/576p/720p/1080i/1080p/1080p24/UHD, 3D frame-packing 720p/1080p24.
Audio Characteristics
(Nominal specification) Frequency: 20Hz – 20kHz (±0.2dB), 20Hz – 96kHz (-3.5dB ~ +0.05dB)
Signal-to-Noise Ratio: >105dB (A-weighted)
THD+N: < 0.0012% (1kHz at 0dBFS, 20kHz LPF)
General Specification Power Supply: ~100V – 240V, 50/60Hz AC
Power Consumption: 40W (Standby: 0.5W in Energy Efficient Mode)
Dimensions: 16.9 x 11.3 x 4.1 inches (430mm x 287mm x 105mm)
Mass: 9.9 lbs (4.5kg)
Operating Temperature 41°F - 95°F
5°C - 35°C
Operating Humidity 15% - 75%
No condensation
Parts & Labor Warranty 2 Years
https://www.oppodigital.com/blu-ray-bdt-101CI/blu-ray-BDT-101CI-Features.aspx
Manosahead
