OPPO BDP-95EU
Πώλειτε το κορυφαίο Universal Network 3D Blu-ray Player oppo bdp-95 σε άψογη κατάσταση.
Link:
http://www.oppodigital.co.uk/ecommerce/product/BDP-95EU.aspx
Τιμή 800 ευρώ
Features and Specifications
  • Dual ES9018 SABRE 32-bit Reference DAC
  • Balanced Stereo XLR
  • Toroidal Transformer
  • Exceptional picture and sound quality
  • Blu-ray 3D™
  • 2nd generation Marvell Qdeo™ video processing
  • Network streaming
  • Advanced DVD up-conversion to 1080p
  • SACD, DVD-Audio/Video, HDCD
  • FLAC 5.1 to 24bit 192KHz via eSATA, USB, Disc or Network
  • DVD-R or DVD-ROM recorded with high resolution WAV files, such as HRx discs released by Reference Recordings and Hi Rez DVD-ROM by M.A Recordings, can be player back directly on the BDP-95EU
  • Wireless-N (Wi-Fi 802.11n)
  • eSATA & Dual USB 2.0 ports with NTFS support
  • Dual HDMI outputs
  • External IR & RS232 control for complete system integration
  • Disc Types* BD-Video, Blu-ray 3D, DVD-Video, DVD-Audio, AVCHD, SACD, CD, HDCD,
    Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE, BD-R/RE DL
    BD Profile BD-ROM Version 2.4 Profile 5 for 3D (also compatible with Profile 2, Profile 1 Version 1.0 and 1.1)
    Internal Storage 2GB (Approximately 1GB available for BD-Live persistent storage. Actual storage varies due to system usage)
    Output Multi-Channel Analog Audio: 7.1ch, 5.1ch, or stereo
    Dedicated Stereo Analog Audio: XLR balanced and RCA single-ended
    Digital Audio: Coaxial, Optical
    HDMI Audio: Stereo, up to 7.1ch high-resolution PCM, up to 5.1ch DSD, bitstream or LPCM conversion of Dolby Digital, Dolby Digital Plus, Dolby TrueHD, DTS, DTS-HD High Resolution Audio, and DTS-HD Master Audio.
    Analog Video: Composite, Component Video (Y/Pb/Pr, 480i/480p, 720p/1080i available for non-restricted content only)
    Digital Video: HDMI with HDCP (NTSC: 480i/480p/720p/1080i/1080p/1080p24, PAL 576i/576p/720p/1080i/1080p/1080p24)
    Video Characteristics Composite Video Amplitude: 1.0Vp-p (75Ω)
    Component Video: Y: 1.0Vp-p (75Ω), Pb/Pr: 0.7Vp-p (75Ω)
    Audio Characteristics** Frequency: 20Hz - 20kHz (±0.2dB), 20Hz - 96kHz (±1dB)
    Signal-to-Noise Ratio: >125dB (A-weighted, with auto-mute), >115dB (A-weighted, without auto-mute)
    THD+N: <0.0003% or -110dB (1kHz 192/24 at 0dBFS, 20kHz LPF), <0.002% or -95dB (1kHz 44.1/16 at 0dBFS, 20kHz LPF)
    Output Level: 2Vrms at 0dBFS (RCA), 4Vrms at 0dBFS (XLR)
    General Specification Power Supply: ~ 100V - 120V or 200V - 240V, 50/60Hz AC
    Power Consumption: 45W (0.5W Standby)
    Dimensions: 430mm x 311mm x 98mm, 16-7/8 x 12-1/4 x 4 inches
    Mass: 7.3kg / 16 lbs
    Operating Temperature 5°C - 35°C
    41°F - 95°F
    Operating Humidity 15% - 75%
    No condensation
Ενημερωτικά και επειδή βλέπω τιμή -10%, αν έχει περάσει μήνας δεν απαιτείται μείωση.
Θάνος Γαλάνης
