Optoma HD720X...699 ευρω
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Απο το θεμα για τον 1080ρ με τα 1499 ευρω μας προεκυψε και αλλο τεφαρικι
Ιδου ο νεος "μικρος" Optoma στα 720ρ και σε τιμη 699 ευρω
[-] Specifications <TABLE id=1 style="MARGIN-TOP: 4px" cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR class=Pdt_fiche_fond1><TD align=left>
Technologie​
Technology </TD><TD align=right>
DLP 720p Darkchip2​
DLP 720p Darkchip2 </TD></TR><TR class=Pdt_fiche_fond2><TD align=left>
R&eacute;solution​
Resolution </TD><TD align=right>
1280 x 720 pixels​
1280 x 720 pixels </TD></TR><TR class=Pdt_fiche_fond1><TD align=left>
Pr&eacute;sence de Lens Shift H/V​
Presence of Lens Shift H / V </TD><TD align=right>
Non / Non​
No / No </TD></TR><TR class=Pdt_fiche_fond2><TD align=left>
Autonomie de l'ampoule (donn&eacute;e constructeur en heures)​
Autonomy of the bulb (given manufacturer in hours) </TD><TD align=right>2000 </TD></TR><TR class=Pdt_fiche_fond1><TD align=left>
Luminosit&eacute; (Lumens)​
Brightness (Lumens) </TD><TD align=right>1000 </TD></TR><TR class=Pdt_fiche_fond2><TD align=left>
Contraste :)1)​
Contrast (1) </TD><TD align=right>3000 </TD></TR><TR class=Pdt_fiche_fond1><TD align=left>
Niveau sonore mode standard (dB)​
Sound level standard mode (dB) </TD><TD align=right>30 </TD></TR><TR class=Pdt_fiche_fond2><TD align=left>
Niveau sonore mode &eacute;co (dB)​
Eco mode noise level (dB) </TD><TD align=right>28 </TD></TR><TR class=Pdt_fiche_fond1><TD align=left>
Enceintes int&eacute;gr&eacute;es​
Speakers included </TD><TD align=right>
Non​
No </TD></TR></TBODY></TABLE><!-- /item1 --><!-- item 2 cach&eacute; -->
Accessories [+]
<!-- item 1 affich&eacute; -->[-] Accessories <TABLE id=1 style="MARGIN-TOP: 4px" cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR class=Pdt_fiche_fond1><TD align=left>
Possibilit&eacute; de montage au plafond​
May be mounted on the ceiling </TD><TD align=right>
Oui​
Yes </TD></TR><TR class=Pdt_fiche_fond2><TD align=left>
T&eacute;l&eacute;commande fournie​
Remote Control Provided </TD><TD align=right>
Oui​
Yes </TD></TR><TR class=Pdt_fiche_fond1><TD align=left>
C&acirc;bles vid&eacute;os fournis​
Videos provided Cables </TD><TD align=right>NC </TD></TR></TBODY></TABLE>
<!-- /item2 --><!-- item 3 cach&eacute; -->[+] Sorties Starters
<!-- item 1 affich&eacute; -->[-] Sorties Starters <TABLE id=1 style="MARGIN-TOP: 4px" cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR class=Pdt_fiche_fond1><TD align=left>
Entr&eacute;e vid&eacute;o HDMI​
Video input HDMI </TD><TD align=right>
Oui​
Entr&eacute;e vid&eacute;o DVI​
Entry DVI video </TD><TD align=right>
Non​
No </TD></TR><TR class=Pdt_fiche_fond1><TD align=left>
Entr&eacute;e S-Vid&eacute;o (Y/C)​
Entry S-Video (Y / C) </TD><TD align=right>1 </TD></TR><TR class=Pdt_fiche_fond2><TD align=left>
Entr&eacute;e vid&eacute;o composante (YUV ou Y/Pb/Pr)​
Video Input component (YUV or Y / Pb / Pr) </TD><TD align=right>1 </TD></TR><TR class=Pdt_fiche_fond1><TD align=left>
Entr&eacute;e vid&eacute;o composite RCA (CVBS)​
RCA Composite Video (CVBS) </TD><TD align=right>1 </TD></TR></TBODY></TABLE>
<!-- /item3 --><!-- item 4 cach&eacute; -->Dimensions [+]
<!-- item 1 affich&eacute; -->[-] Dimensions <TABLE id=1 style="MARGIN-TOP: 4px" cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR class=Pdt_fiche_fond1><TD align=left>
Poids (en kilos)​
Weight (kg) </TD><TD align=right>2 </TD></TR><TR class=Pdt_fiche_fond2><TD align=left>
Largeur (en cm)​
Width (in cm) </TD><TD align=right>26 </TD></TR><TR class=Pdt_fiche_fond1><TD align=left>
Hauteur (en cm)​
Height (cm) </TD><TD align=right>10 </TD></TR><TR class=Pdt_fiche_fond2><TD align=left>
Profondeur (en cm)​
Depth (cm) </TD><TD align=right>25 </TD></TR></TBODY></TABLE>
<!-- /item4 -->
http://64.233.179.104/translate_c?h...vis-redac-2875/videoprojecteur-optoma-hd720x/
jimacid
