Pace MPEG4 HDTV-Receiver DS810
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Pace demonstrates its first HDTV hDTV-Receiver DS810 for the new HDTV standard MPEG-4. The receiver is developed for the European market and connects the past HDTV standard MPEG -2 with the future standard MPEG-4. The DS810 extends thereby the application possibilities of the highly soluble television HDTV. This model will also presumably be offered starting from November for the HDTV program by premiere.
As a multi-format decoder the TV households of HDTV programs become both with the existing standard quality (standard definition SD) with the DS810 and in the new MPEG-4 AVC/H-264 compression standard to receive to be able.
The hp box DS810 presented for the first time publicly during the AngaCable 2005 is the entrance in a Receiver series, which will continue to supplement Pace and to also inexpensive entrance models with the current in each case technical developments to belong. HDTV receivers on MPEG4-Basis are planned for 2006.
The DS810-Receiver supports audio standards such as Dolby digital plus, AAC HE, DiSEqC 2,0, the video interface HDMI with the copy protection HDCP, 3DES, AES and offers a USB 2.0-Schnittstelle.
The efficiency of the DS810 is based on 300 MHz a processor with 420 MMPIS. The DS810 has (alternatively) an integrated coding system (Conditional ACCESS - APPROX.) and an interface (Common interface - CI) with an inserted PCMCIA pit, in order to use different coding procedures.
Among the further equipment characteristics rank:
* digital copy protection HDCP
* Favorite list
* multilingual menu guidance
* fast and detailed EPG with 8-Tages-Vorschau
* Data processing multicolored title
* Child protection
The equipment is supplied with an automatic software Setup and a hp mixing CCIT place for the home cinema receipt, in addition also the conventional SD- of terminals can be attached beside HDTV. The DS810 is supplied from the outset with the Pace control display and a EPG as well as with a covered Smart Card reader and CI pit, in order to make various applications possible.
Ioanniss
