Palmer Orbit 11
dapost
Rehdeko & Harbeth lover
dapost
Είναι δυνατόν; 800 ευρώ; Ας περιμένουμε τις κλιπο-μετρήσεις.
Coaxial true point source (6.5" mid + 1" tweeter)
Impulse compensated dual 8" woofers for tight, resonance-free bass
True 3-way design for full-range accuracy and clarity
1000 W Class-D amplifier delivers high dynamic range
Cardioid design for controlled directivity and reduced room interaction
120° ×120° constant directivity provides uniform coverage
FIR filters for linear phase with minimal latency
Ultra Wide frequency range (28 Hz–28 kHz @ -3 dB)
Advanced low-end design improves wall coupling and reduces cancellations
Clean control panel with desk & wall presets for efficient setup
High-resolution 96 kHz / 24-bit DAC and DSP
Analog and AES3 inputs for seamless integration
Die-cast aluminium housing for ultra-low resonance
απίθανο όντως να κάνει 1600 ευρώ το ζεύγος!
gagakostas
