Panasonic AG-HVX200 Hi-Def Camcoder
Panasonic Broadcast has announced that its AG-HVX200, the industry’s first handheld high definition solid-state memory camcorder, will begin delivering to resellers on 29 December. The HVX200 uniquely combines multiple high definition and standard definition formats, multiple recording modes and variable frames rates, and the vast benefits of P2 solid state memory recording in a rugged, compact design.
Panasonic announced introductory pricing for the HVX200 at $5995, or $7295 list price for the camcorder and two 4GB P2 cards ($9995 with two 8GB P2 cards). ‘I want to thank the substantial number of customers who have patiently awaited the HVX200’s arrival. The wait is nearly over’, said John Baisley, President, Panasonic Broadcast & Television Systems Company. ‘I am confident that the HVX200’s powerful capabilities and stunning image quality will truly inspire a new level of high definition users.’
With the ability to capture images in 21 video formats, the ultra-versatile HVX200 records in high definition in 1080i and 720p in production-proven 100Mbit/s DVCPRO HD quality. The DVCPRO HD format offers cost-effective, intra-frame compression, where each frame stands on its own for editing, and its full 4:2:2 colour sampling allows the image to hold up under colour correction.
The camera records video on a P2 card as IT-friendly MXF files in 1080/60i, 30p and 24p; in 720/60p, 30p and 24p; in 50Mbit/s DVCPRO50 and in 25Mbit/s DVCPRO or DV. With a pair of Panasonic’s new 8GB P2 cards (model P2C008HG), the HVX200 records for 64 minutes in DVCPRO or DV, 40 minutes in 720p, 32 minutes in DVCPRO50, and 16 minutes in 1080/60 and 720/60.
The HD and SD video recorded on the P2 card can be downloaded to a nonlinear editing system or server, or edited virtually instantly from the P2 card by connecting to a FireWire or USB 2.0 interface. P2 cards mount like a regular hard disk drive from a NLE system’s point of view, which eliminates the time-intensive task of digitising footage.
The multi-format camera has two P2 card slots, and offers a variety of record modes including hot-swap recording to ensure continuous recording; loop recording; pre-record (up to 7 seconds in DVCPRO and 3 seconds in DVCPRO HD); one-shot record (from 1 frame to 1 second) and interval record (from 2 frames to 10 minutes).
With cutting-edge P2, all moving parts are eliminated from the recording path, which ensures that the HVX200 is extremely reliable and resistant to environmental conditions including the shock and humidity that threaten camcorders based on mechanical recording transports. For added flexibility, the HVX200 is also equipped with a Mini-DV tape drive for shooting 4:3 and 16:9 images on DV tape in 60i, 30p and 24p.
The HVX200 inherits the variable frame rate capability of Panasonic’s popular, shoulder-mount AJ-HDC27 VariCam HD Cinema camcorder. The HVX200 can capture fast or slow action in 720p at various frame rates - the first time this function is available in a handheld camera. The shooting frame rate in 720p native mode can be set for any of 11 steps between 12fps and 60fps including 24fps and 30fps. By using the camera to play back the recording at the normal rate, the shooter can preview the off-speed effect right on the spot, without the need for a frame rate converter.
Furthermore, the HVX200 can down-convert off-speed recordings in 720p recorded on a P2 card and copy it to a mini DV tape. This allows you to create special off-speed effects during DV production - a technique previously possible only with a complete VariCam system.
And like VariCam, the HVX200 offers advanced Gamma modes; the camera has eight gamma modes including Cine-Like Gamma to give recordings the characteristic warm tone of film recordings. For newsgathering, a news gamma curve assists a news photographer by allowing him to suppress over-saturated highlight areas during sudden contrast changes.
The AG-HVX200 combines native progressive 16:9 1/3-inch 3-CCDs and a wide-angle, 13x Leica Dicomar HD lens (with optical image stabilisation and a super-smooth, cam-driven manual zoom) to cover a wide range from 4.2- to 55mm (35mm equivalent of 32.5- to 423mm). Its large viewfinder and 3.5-inch LCD monitor should make it easy to view content.
For example, in 16:9 widescreen mode, the camcorder can display images on the LCD monitor in letterbox, which allows the user to view vital camera operating information in areas above and below the image. In addition, the LCD permits the shooter to view and select thumbnail clips to speed editing, and allows random access to the thumbnail-displayed scenes (on the P2 card) for instant playback and the creation of an in-camera storyboard.
Audio performance comes in the way of 4-channel non-compressed 48KHz/16-bit digital audio in DVCPRO HD and DVCPRO50, which is ideal for audio sweetening in post production; and two channels in DVCPRO and DV. The HVX200 is loaded with system interfaces (including FireWire and USB 2.0), and professional interfaces including two XLR audio (with +48 volt phantom power) inputs, a component (D4) output, composite in/out, S-video in/out, audio (RCA) in/out, and headphone output.
For operator convenience, the camcorder is highly customisable with features including six user scene files, three user setup buttons, and Camera Setup Memory (up to four camera setups can be saved to a SD Memory card for transfer to another camera).
Other key features include: jam sync for multi-camera shoots; minimum illumination of 3 lux for low-light shooting; Shot Mark function to speed editing; built-in SMPTE time-code generator/reader; level-adjustable audio levels; ND Filter that increases gain up to 18 dB; a Slow Speed and High Speed Shutter; an Auto/Manual Mode Selector; White Balance with Auto Tracking White Function; and Trigger and Zoom Controls on the camera’s upper handle grip.
Τιμές από 6000$USD και άνω!
Αναλυτικά τα χαρακτηριστικά :
• True high definition image quality with low-compression DVCPRO HD intraframe recording
• Multiple formats: DVCPRO HD, DVCPRO 50, DVCPRO, DV selectable
• High definition recording formats: 1080/60i, 1080/24p, 1080/24pA, 1080/30p, 720p (variable frame rates)
• Standard definition recording formats: 480/60i, 480/24p, 480pA, 480/30p
• CineSwitchTM technology for variable frame rates in 720p mode: 12, 18, 20, 22, 24, 26, 30, 32, 36, 48, 60fps
• 1/3" 16:9 native high-sensitivity progressive 3-CCD with 1080/60p scanning
• New DSP with 14-bit A/D conversion and 19-bit internal processing for unprecedented accuracy
• 16:9/4:3 switchable for standard definition recording, 16:9 native for HD
• Wide angle Leica Dicomar HD lens with optical image stabilizer (motorized/manual mode switchable)
• High resolution 235,000 pixel .44" electronic viewfinder (EVF) with 90 degree tilt and detail function (for easier focusing)
• High resolution 210,000 pixel flip-out 270 degree 3.5" LCD display
• Thumbnail display for easy searching and file information
• Auto/manual focus with focus assist (even during recording)
• Cam-driven manual zoom
• 13X zoom range: focal length = 4.2 to 55mm (35mm equivalent: 32.5 to 423)
• Advanced gamma functions and eight gamma settings including two CineGammaTM modes and NewsGammaTM mode
• Advanced image adjustments: color matrix, detail, chroma phase, color temp, knee points
• Two ND filters: 1/8, 1/64
• 82mm filter diameter
• Two P2 card slots with hot swap capability
• Hot swap, loop, pre-record (3 seconds in HD, 7 seconds in SD), one shot, and interval recording functions
• Mini-DV tape transport for DV recording
• Internal downconversion and frame rate conversion from HD source recorded on P2 cards to Mini-DV tape
• 48kHz 16-bit 4-channel PCM audio (2 XLRs with phantom power)
• Built-in stereo microphone (unidirectional microphone optional)
• Audio dials and flexible input selection
• Analog component (Y, Pb, Pr) output
• Composite input/output
• S-Video input/output
• Standard IEEE 1394 interface
• External recording to FOCUS FireStore FS-100 via IEEE 1394 streaming
• Host mode for transferring previously recorded content on P2 cards to an external hard drive via IEEE 1394
• Compatible with nonlinear editing systems from Apple, Avid and Canopus
• USB 2.0
• SD memory card slot for sharing scene files
• Remote control for zoom, record (start/stop)
• Remote control for focus, iris control
• SMPTE timecode reader/generator with timecode matching with multiple cameras via IEEE 1394
• SMPTE color bars
• Three programmable user buttons
• Six pre-set scene files (user programmable)
• Shot marker function
• Slow, synchro and high speed shutter
• White balance with auto tracking white function
• Trigger and zoom control on upper handle grip
• Ultra-tough magnesium alloy chassis
• Supplied accessories include CG-AD54SE/1B Lithium-Ion 7.2V / 5400mA snap-on battery, AG-B15 AC adaptor/battery charger, microphone holder, component video cables with RCA-BNC adaptors, remote control, shoulder strap and instruction manual
The HD Revolution has begun. Now shipping!
New AG-HVX200 packages now available for order:
AG-HVX200 + one 4GB P2 card - U.S. List Price $6,645.00
AG-HVX200 + two 4GB P2 cards - U.S. List Price $7,295.00
AG-HVX200 + five 4GB P2 cards - U.S. List Price $9,245.00
AG-HVX200 + two 8GB P2 cards - Special Package Price $9,995.00. Save $400!
Πηγή : www.panasonic.com
V
VIDEOMIX
SUPER όμορφη, SUPER SUPER γενικά. Η αγαπημένη μου στις κάμερες PANASONIC περνά στην αντεπίθεση. :)
s channel
