m1ts0s
News poster
http://www.theverge.com/2014/9/15/6151671/panasonic-leica-cm1-android-cameraphone
"The CM1 comes with a 1-inch sensor that dwarfs most imaging sensors in smartphones today and is on a par with what you'd find inside Sony's RX100 and Nikon's 1 Series of cameras. It has a 20-megapixel resolution and is paired with an f/2.8 Leica lens, a mechanical shutter, and a manual control ring. Interestingly, the lens extends out of the body, but is not a zoom lens, its adjustments are purely for focusing purposes."
"The rest of the CM1's specs are pretty conventional for modern smartphones. It has a 4.7-inch 1080p screen and runs Android 4.4 on a 2.3GHz quad-core Snapdragon processor. 2GB of RAM and 16GB of built-in storage are provided, with a microSD card slot allowing expansion by up to an extra 128GB — handy since this camera can also shoot 4K video."
900 EUROS
900 EUROS
