PANASONIC LUMIX DMC-FZ45 ΜΕ ΕΧΤRA
Αποφασισα να καταληξω και να μεινω μονο με την NIKON D3100 μου .
Η μηχανη ειναι ΕΛΛΗΝΙΚΗΣ ΑΝΤΙΠΡΟΣΩΠΕΙΑΣ ( οχι παραεισαγωγη - εβαυ - ntsc κλπ ) .
Αγορασμενη 20-01-2011 ( λιγοτερο απο μηνα την εχω ) .
Εχω τραβηξει περιπου στις 100 φωτο για τις δοκιμες μου .
Με το κουτι της - χαρτια - εγγυηση κλπ
TIMH 320 ΕΥΡΩ
Μαζι εχω :
1. Τσαντα μεταφορας
Specification:
  • Color: Black
  • Material: High Density Fabric
  • Inner Size: 175x140x100mm (6.89x5.52x3.94 inch)
  • Accessory: One Shoulder Strap
2. Δευτερη μπαταρια OEM αχρησιμοποίητη ( DMW-BMB9E )
3. Pixco hand grip strap
4. 3.5(52mmx70mm) inch screen protector
+ 1 ακομα extra
52mm Polarized PL + UV + FD Camera Lens Filter Kit Set
"A must have for all photographers with 52mm lenses - this set of 3 circular filters will help you achieve the effects you desire in a variety of different situations and scenarios.
Presented in a smart, black case, this set of 3 includes the following filters:
UV Filter:
# No more blurry edges - get crisp, clear photos every time
# No need to change when using different film types – works with colour and black & white
# Absorbs unwanted light rays without affecting the colour balance
CPL Filter:
# Eliminates reflections from non-metalic surfaces
# Increases contrast and colour saturation
F-DL Filter:
# Removes the yellowy green cast which appears when shooting under fluorescent lighting
# Increases colour saturation when shooting in natural lighting conditions
These filters will also help protect your expensive lenses from dust and scratches. They are brand new and supplied in a smart pocket-sized case.
* For use with ALL 52mm camera lenses
* Metal ring frame
* Use the right filter for the job - each filter is marked with its type
* Protective case included
Κ.Κωνσταντίνος
