Panasonic PT-AE8000U/PT-AE6000E
ετσι λενε .......:126:
Panasonic PT-AE8000U η Panasonic PT-AE6000E
......βελτιωμενος στην αντιθεση και 3d ρυθμισεις....
Απάντηση: JVC DLA-X35, DLA-X55, DLA-X75 et DLA-X95
Panasonic's most popular projector has been updated by the PT - AE8000 E Full HD 3D LCD home theater projector with a 1080p (1,920 x 1,080 pixel) resolution.
The PT- AE8000 E / has been redesigned from the ground up to achieve higher basic 2D performance and packed with unique 3D features to deliver the 3D quality demanded by the Hollywood professionals.
Thanks to the updated optical engine, which produces an incredible high contrast ratio (400,000:1) and brightness (2,200 lumens), the PT-AE8000E delivers both stunning 2D images and comfortable and immersive 3D viewing experience at home.
The PT- AE8000 E’s key 3D projection technologies were developed in collaboration with Panasonic Hollywood Laboratory engineers, who are heavily engaged in the creation of 3D Blu-ray™ discs.
They have taken key roles in establishing the industry standards for 3D and bringing the experience from large screens to homes.
Through this joint effort, the PT-AE8000E has been redesigned from the ground up to achieve higher basic 2D performance and packed with unique 3D features to deliver the studio-grade 3D content to the consumer.
The PT- AE 8000 E comes rich with features for those looking to customize their home theaters. Many Blu-ray™ discs and DVDs come in aspects that are even wider than the projector’s 16:9 aspect ratio to match the image size (2.35:1) seen at movie theaters.
The projector’s Intelligent Lens Memory feature makes it possible for the user to easily program up to six different zoom/focus positions.
Automatic switching between 16:9 and 2.35:1 video content is also possible thanks to the signal aspect detection capability on the PT-AE8000E.
Green Product
In addition to its outstanding features, the new PT-AE8000E is also an ecological product. Its intelligent power management system reduces the lamp power to the exact required level of brightness depending on the content being displayed. Advanced Panasonic digital circuitry intelligently determines the necessary power output by analyzing more than 3 billion different image patterns.
This advanced analysis process reduces the main power consumption by as much as 10 percent when the Dynamic Iris function is operating thus saving energy.
Specifications SUBJECT TO CHANGE WITHOUT NOTICE
Power supply 100 – 240 V AC, 50/60 Hz
Power consumption 285 W (0.08 W in standby mode)
LCD*1 panel Panel size 18.7 mm (0.74 in) diagonal (16:9 aspect ratio)
Display method Transparent LCD panel (× 3, R/G/B)
Drive method Active matrix
Pixels 2,073,600 (1,920 × 1,080) × 3, total of 6,220,800 pixels
Lamp*2 200 W UHM lamp
Lens Powered zoom/focus lenses (1.35:1–2.70:1), F 1.9 – 3.2,f 22.4 – 44.8 mm
Projection size 2D projection 1.02–7.62 m (40 – 300 inches)
3D projection 1.02– 5.08 m (40 – 200 inches)
Throw distance 1.16–18.08 m (3 ft 11 in to 59 ft 4 in)
Colors Full color (1,073,741,824 colors)
Brightness*3 2200 lumens*4
Center-to-corner uniformity ratio*3 85%
Contrast ratio*400,000:1*5 (full on/full off)
Resolution 1,920 × 1,080 pixels
Scanning frequency RGB fH: 15 kHz – 74 kHz, fV: 24 Hz– 85 Hz, dot clock: 154 MHz or lower
YPBPR (YCBCR) 525i (480i): fH 15.75 kHz; fV 60 Hz,
625i (576i): fH 15.63 kHz; fV 50 Hz,
525p (480p): fH 31.50 kHz; fV 60 Hz,
625p (576p): fH 31.25 kHz; fV 50 Hz,
750 (720)/60p: fH 45.00 kHz; fV 60 Hz,
750 (720)/50p: fH 37.50 kHz; fV 50 Hz,
1125 (1080)/60i: fH 33.75 kHz; fV 60 Hz,
1125 (1080)/50i: fH 28.13 kHz; fV 50 Hz,
1125 (1080)/24p: fH 27.00 kHz; fV 24 Hz,
1125 (1080)/60p: fH 67.50 kHz; fV 60 Hz,
1125 (1080)/50p: fH 56.25 kHz; fV 50 Hz
Video/S-Video fH: 15.75 kHz, fV: 60 Hz [NTSC/NTSC4.43/PAL-M/PAL60]
fH: 15.63 kHz, fV: 50 Hz [PAL/PAL-N/SECAM]
Optical axis shift*6 Vertical: ±100%, horizontal: ±26%
Keystone correction range Vertical: approx. ±30°*7
Installation Ceiling/desk, front/rear (menu selection)
On-screen menu languages English, French, German, Spanish, Italian, Chinese, Korean, Russian,
Swedish, Danish, Norwegian, Polish, Czech, Hungarian, Portuguese,
Thai, Japanese
Terminals HDMI IN HDMI connector × 3, HDMI™ (Deep Color, x.v.Color™*8 , CEC*9 ),
HDCP compliant, supports HDAVI Control Version 5
COMPUTER (RGB) IN D-sub HD 15-pin (female) × 1
RGB signal R, G, B: 0.7 Vp-p (1.0 Vp-p for sync on G), 75 ohms,
HD/SYNC, VD: TTL (positive/negative polarity compatible)
NOTE: HD/SYNC, and VD terminals do not accept tri-level sync signals.
YPBPR/YCBCR signal Y: 1.0 Vp-p (including sync signal), PB/PR: 0.7 Vp-p, 75 ohms
COMPONENT IN RCA pin (Y, PBP/CB, PR/CR) × 3
Y 1.0 Vp-p, 75 ohms,
PB/CB, PR/CR 0.7 Vp-p, 75 ohms
TRIGGER IN / TRIGGER OUT / 3D SHUTTER OUT
M3 jack × 2 (operate as 3D IR transmitter connectors)
12 V, max. 100 mA (input/output/3D shutter output selectable using
on-screen menu)
VIDEO IN RCA pin × 1, 1.0 Vp-p, 75 ohms
S-VIDEO IN Mini DIN 4-pin × 1, Y: 1.0 Vp-p, C: 0.286 Vp-p, 75 ohms
SERIAL IN D-sub 9-pin × 1 for external control (RS-232C compliant)
Power cord length 3.0 m (9 ft10 in)
Cabinet materials Molded plastic (PC+ABS)
Dimensions (W × H × D) 470 mm × 151 mm × 364 mm*10 (18-17/32˝ × 5-15/16˝ × 14-11/32˝)*1 0
Weight*1 1 Approx. 8.7 kg (19.2 lbs)
Operation noise*3 22 dB (lamp power: eco)
Operating temperature 0°– 40°C (32°–104°F)
Operating humidity 20%– 80% (no condensation)
See also Panasonic AE8000 Review
Please note above specifications are estimates only subject to release of the New Panasonic AE 8000 in Australia.
Nelsy
Ιεράπετρα
Αυτό είναι κοντράστ,όχι αστεία...μπορεί να έχουν κάνει και λάθος...να είναι 4.000.000/1:405:
Απάντηση: Panasonic PT-AE8000U/PT-AE6000E
....υπαρχει και καλυτερο(Sony, ο βιντεοπροβολέας μπορεί να επιτύχει λόγο δυναμικής αντίθεσης 10.000.000:1) :116:
Nelsy
Ιεράπετρα
Το ξέρω,απατεωνιά...για αυτό δεν ασχολούμαι:116:...και 4Κ,μπουχτίσαμε στις ταινίες...
στο θέμα μας...πότε θα βγει ο καινούργιος Panny;
knazito
