Panasonic PT-RW430U LED/Laser Projector Review
The Panasonic RW430U is a highly capable installation projector that is ideal for conference room or classroom use even without its hybrid light source. It is capable of 24/7 operation, and its heat pipe cooling system keeps the internal components from degrading prematurely. One operating mode enables the unit to be installed in vertical orientation, allowing for portrait projection in digital signage applications. HDBaseT compatibility, a 2:1 zoom lens and manual H/V lens shift make the RW430U easy to set up in most classrooms and conference rooms, while edge blending and color matching features make the projector appropriate for large-scale multi-projector image walls. When you tack on the hybrid 20,000-hour light source and filter-free design, the RW430U starts to look like a sure bet for business and education use.
Source: projectorcentral.com
JAndronikos
