Panasonic TH-50PHD7UY Plasma TV
Κώστας Φ.
Κούκλα η άτιμη.....
Plasma Display Specifications
Screen Size 50" diagonal
Screen Aspect 16:9
Contrast Ratio 3000:1
Brightness 550cd/m2
Pixel Pitch 0.81 x 0.81 mm
hSync 15 - 110 kHz
vSync 48 - 120 Hz
Color System NTSC, PAL, PAL 60 Hz, SECAM
Data Signals VGA, SVGA, XGA, SXGA, UXGA
TV Scan Lines 480i, 480p, 720p, 1080i
Input Terminals
Composite Video 1 (BNC)
S-Video 1 (4-pin mini DIN)
RGB Component Video 1 (BNC x 5)
VGA RGB Signal 1 (15-pin mini d-Sub)
Stereo Audio In 2 (RCA L/R)
PC Audio In 1 (mini stereo plug)
Serial Control (RS232C) 1 (9-pin mini d-Sub)
Output Terminals
Plasma Monitor Accessories
Audio Amplifier 8W x 2
Speakers Optional
Mounting Options Optional Mount Required
Dimensions and General Specs.
Power Supply 100-120V @ 50-60Hz
Power Consumption 480 Watts
Dimensions 47.6" x 28.5" x 3.7"
Weight 94.80 lbs.
FCC Class FCC Class A, Commercial Use
Key Features of the Panasonic TH-50PHD7UY 50" Plasma Monitor
50" Panasonic Plasma TV
1366 x 768 HDTV Resolution, 16:9 widescreen
New Real Black Drive System - achieves Exceptional 3000:1 Contrast Ratio
New Deep Black Filter on front glass
Super Real Gamma System - reproduces 2,048 shades of gradation
Mach Digital Contour Enhancer for 10% brighter, sharper images
Three interchangeable multi fuction slots
Dual picture display and 9 point digital zoom
Industry-leading 60,000 hour panel life
New Screen Saver and Energy Saving Functions
Fanless quiet operation
New HDMI and DVI-D input boards available (optional)
Πηγή: plasmatvbuyingguide.com
intergrale
