Paradigm Concept 4F
Concept 4F is a true full-range hybrid loudspeaker, the perfect balance of powered woofers with a passive upper register array. It features TruExtent® Beryllium 1" tweeters and TruExtent® Beryllium 7" midrange drivers with perforated phase-aligning lenses, and four Ultra-High-Excursion Differential Drive 8.5" woofers in a vibration-cancelling configuration (two front-firing, two rear-firing). Each woofer pair is powered by a separate DSP-controlled 700 W RMS amplifier for a total of 1400 W RMS (2,800 W Dynamic Peak), and combined with exclusive technology like Anthem Room Correction (ARC™) capability. And then some.
Θάνος Γαλάνης
