Κώστας Φ.
Paradigm Electronics introduces the DSP Series subwoofers in which each model features "a forward-firing driver with a CAP™ Carbon/Aramid-Fiber Polypropylene cone that combines with computer optimized ceramic/ferrite magnet structures to reduce inductive distortion while generating a powerful magnetic field. The advanced suspension design (surround/spider/chassis) promotes extended cone excursion while maintaining appropriate control over cone movement. Computer-optimized heatsinks and proprietary AVS™ Airflow Ventilation System aid in increased power handling as well as further reducing distortion.
"The DSP Series’ high-velocity, low-noise dual-port design incorporates critically flared openings to reduce turbulence distortion while ensuring maximum efficiency. The front-ported design also accommodates installation flexibility—the front ports allow DSP subwoofers to be placed discreetly for users who aren’t interested in making a visual statement with their set-up. Finally, the acoustically inert MDF cabinet construction helps eliminate unwanted cabinet resonances while reinforcing enclosure stiffness. All Paradigm DSP Series models feature removable grilles with the company’s new SVS™ Slot Ventilation System, which allows for the release of the enormous air pressure generated by these high-performance designs.
Models are available in Cherry, Rosenut and Black Ash.
6moons.com
