Χαιρετώ και πάλι.
Δίνω τον κονβερτορα μου σε καινουργει κατάσταση 20 ευρώ.
http://www.vvdeals.com/products/PC-VGA-to-TV-Converter-with-Audio_71.html
Overview
PC to TV Converter with Audio
PC to TV Converter with Audio is a newly-designed video converter from us. This PC to TV Converter can convert VGA to composite (Yellow RCA) and/or S-video TV display signal, and is designed with audio output. It is combined USB cable, VGA cable and Audio cable into a single cable converter to get rid of disorder of cables. It also saves the trouble of connecting a separate audio cable between PC and TV, and saves you money to buy several cables. It is with cute looking and is portable, being widely applied to business presentation, education and training center, or home theater for convenient sharing content with others. This portable PC to TV converter makes sharing between PC and TV a breese now and will definitely make your digital life simple.
Highlights:
1, The first PC VGA TO TV Converter to support audio in the world
2, The PC TO TV Converter is small in size, portable, charging via USB, which makes your lecture around the world easier.
3, The PC TO TV Converter supports all computer system like PC, MAC, etc. No need to drive, plug and play.
4, Wide Application
For Home Entertainment – You can combine your home theater system with your PC. Download MPEG-4 movies and enjoy them on your big screen HDTV with your family. PC to TV converter makes home entertainment a breeze now.
For Business/ Work – You can demonstrate the multimedia files in your notebook to yours audience through the large screen television when giving presentation or lecture.
Features:
- 2 Input (PC Input): 1 X VGA; PC audio input
- VGA resolution (PC input): 640 X 480 (60/75Hz), 800 X 600 (60/75Hz), 1024 X 768 (60/75Hz), 1280 X 768 (60HZ), 1280 X 1024 (60HZ);
- 3 Loop-through Outputs (TV out): 1 X -Composite Video, 1 X S-video; Audio L/R output
- Output signal: CVBS (1.0Vpp), S-Video (Y: 1.0Vpp, C: 003Vpp);
- The PC to TV converter supports NTSC (Taiwan, US, etc.) in default and can automatically diagnosis the general TVs in NTSC; it also supports television systems in NTSC-EIAJ (Japan), PAL (Europe, China), PAL-M (Brazil), PAL-N (Uruguay, Paraguay) and so on by revising the setting.
- Output signal impedance: 75Ω;
- Power: DC 5V 1A (it is powered from USB port and no extra power supply is needed) ;
- Working Temperature: 25~75°C;
- Working Humidity: 10% ~ 65%;
- Dimension: 130*75*27 mm (L*W*H)
Application:
-Business presentation,
-Education and training,
-Commercial promotion
-Computer game
- Home theater
Package Include
PC to TV Converter x 1
User Manual x1
Overview
Highlights:
4, Wide Application
Features:
Application:
-Computer game
- Home theater
Package Include
User Manual x1
