Προς πώληση ένας πολύ ξεχωριστός πικαπ σέ πολύ καλή κατάσταση, εμφάνιση και ποιότητα high end, μαζί με την θρυλική κεφαλή Stanton 680 EL καί βελόνα D 6800 EL. Μόνο 250 ευρώ.
Description
The Philips GA 209 is an electronically controlled, fully automatic, two-speed record player combining the following features:
Exceeds the standards laid down by DIN 45500
Automatic start and selection of turntable speed
Automatic sensing of record diameter
Automatic return of pick-up at end of record
Option of manual or automatic operation
Built-in protection against incorrect use
Direct reading stylus force indicator with adjustment between 0.75 and 3 grams
Adjustable side thrust compensation
Universal headshell to carry Super M cartridges, or most other cartridges having 1/2" fixing centres
Photo-electric auto-stop, noiseless in operation and exerting no force on the pick-up arm
Electronic servo-control of the pick-up arm
Fully floating turntable and pick-up arm suspension
Very low wow, flutter and rumble
Low speed DC motor and belt driven platter
72 pole tacho-generator ensures constant turntable speed
Fine adjustment for 33.33 and 45 rpm
Specifications
Drive method: belt drive
Record sizes: 17, 25 and 30cm
Speeds: 33 and 45rpm
Speed adjustment range: +-3%
Wow and flutter: 0.1%
Rumble: -60dB
Stylus force: 0.75 to 3g
Arm friction: 10 mg lateral/vertical
Mains voltage: 110, 127, 220 or 240V AC, 50 or 60Hz
Power consumption: 8 watts
Description
Specifications
Rumble: -60dB
276,1 KB Προβολές: 0
268,4 KB Προβολές: 0
167,5 KB Προβολές: 0
154,5 KB Προβολές: 0
210 KB Προβολές: 0
246,4 KB Προβολές: 0
219,3 KB Προβολές: 0
