PHILIPS RC9800I/05 Touch screen remote control
Simple, yet revolutionary control
This touchscreen wireless multimedia remote control offers a simple Activity-Based interface to control the home entertainment experience. With its simple on-screen setup wizard, the remote can be setup in a few simple steps, ready to go!
Picture / Display
Touch-sensitive screen : Touch screen
Backlight : yes
Display backlight : White
Display colours : 65,536
Diagonal screen size (inch) : 3.5 in
Resolution : 320 x 240 pixels
Infrared Capabilities
Universal infra red code database : Yes
Learning IR codes : Yes
Learning frequency range : 20 kHz to 70 kHz and 455 kHz
Number of brands in database : Over 1100
Connectivity
Built-in wireless technology : 802.11b
Front/side connections : USB
Internet connection options : Upgradeable
Remote control extender : via WiFI
Convenience
Ease of installation : Wizard guided installation
Ease of Use : Graphical user interface
Language available: UI : English
Front controls : Volume up, Volume down, Mute, Channel up, Channel down, Cursor up / down / left / right, Power / standby, Home, Back, Page
Automatic power off : Yes
Battery low indication : yes
Clock with calendar : yes
Battery charging indication : Yes
Multimedia Applications
Playback formats : MP3, m3u
Still picture playback
Picture compression format : BMP, GIF, JPEG
Loudspeakers
Built-in speakers : 1
Software
Philips Media Manager : UPnP multimedia content server
Power
Battery type : LI-Polymer
On/Off switch : Yes
Mains power : AC 220-240 V, 60 Hz
Number of included adapters : 1
Battery capacity : 1700 mAh
Charging time : approximately 3 hours hr
Dimensions
Product dimensions (WxDxH) : 149 x 101 x 24 mm
Temperature range (Operation) : +5° C to +45° C
Box height : 284 mm
Box depth : 78 mm
Box width : 228 mm
Accessories
Docking Station : with 3.5 mm audio line-out
USB cable : yes
Printed user guide : Eng/Fr/Esp/Ger/Ned
User Guide on CD-ROM : yes
Quick start guide : UK/F/D/NL/E/I/P/GR/S/N/DK/FIN
Guarantee booklet : Global version
Warranty card : yes
Πανέμορφο και εκπληκτικό σε δυνατότητες.........
Πολύ θα το ήθελα, αλλά θα'ναι κομματάκι ακριβό!! :roll: :wink:
Παναγιώτης55
