Phonomena!
PHONOMENA!
At last! A truly affordable phonostage with high-end refinement. Musical Surroundings introduces: Phonomena. No op-amps in this signal path! Compare the guts of Phonomena with other budget phono stages. Value, quality, adjustability and, most of all, great sound, make this first offering under the Musical Surroundings marque something phonomenal!
• American made • Discrete transistor topology
• Class A operation • Dual mono audio layout
• Super matched pair of low noise input transistors
• Adjustable gain: 40 - 60 dB in 16 steps
• Adjustable loading: 30 ohms - 100 k-ohms in 128 steps
• Adjustable capacitance • Remote AC Power Source
• Constant ON feature for thermal stability
• Now Available: Optional Battery Power Supply for super low noise
• Retail price $600
The Battery Power Supply (BPS) isolates your Phonomena phono preamp from the AC power source during listening sessions, providing your system improved performance in the areas of resolution, ease and dynamics.
The BPS is finely tuned to the Phonomena; a star ground was designed in the Phonomena for use with the BPS. The BPS contains two 8-cell NiMH battery packs, each dedicated to a power supply rail. The batteries offer large energy storage and a low source impedance, as well as "no memory" operation, allowing complete recharging between listening sessions.
• The charging cycle is 4 times faster than the discharge cycle, meaning more listening time.
• Even in "line connected" mode, performance is enhanced.
• The BPS is available in either silver or black to match your Phonomena.
Phonomena Battery Power Supply: $600
  • rose.athens
Nikos88
