Phonostage από την THORENS
Phono Preamp MM 001
This phono preamplifier includes a high-quality RIAA-equalizer for moving-magnet (MM) phono cartridges. It has been designed to go with high-level preamplifiers or integrated amplifiers that no longer feature a built-in phono stage. Therefore, the MM 001 is connected to a high-level input, such as Aux, Tape, etc.
A pair of excellent RCA signal leads and an external power supply are provided with the unit.
technical data
Input sensitivity 5 mV / 1 kHz / 47 kOhm
Output 200 mV / 1 kHz
Distortions < 0,002 %
RIAA-Equalization 20 Hz - 20 kHz, +/-0,5 dB
Singnal-to-noise ratio > 82 dB/A
Power supply 15 - 16 V / 20 mA, AC
Dimensions (W x H x D) 3.9 x 1.4 x 3.2 " (98.0 x 35.0 x 80.0 mm)
antikotsos
