PIONEER A/V VSX-D712-S
PIONEER RADIO AUDIO VIDEO MULTICHANNEL RECEIVER MODEL VSX-D712-S
ελαφρώς μεταχειρισμένο και πλήρες λειτουργικό με το τηλεκοντρόλ του. τιμή 100 ευρώ
αποστολη σε ολη την ελλαδα με ταχυδρομείο αντικαταβολή, με εξοδα αποστολής 8 ευρω.
SpecificationsKey featuresVSX-D712-SSurround Sound FormatsVSX-D712-SPower OutputVSX-D712-SConstructionVSX-D712-SAmplifier SpecificationsVSX-D712-STuner SpecificationsVSX-D712-SInput & Output connectionsVSX-D712-SAudio FeaturesVSX-D712-SVideo FeaturesVSX-D712-SRemote ControlVSX-D712-SInterfaceVSX-D712-S Dolby Digital EX (pre out) / DTS-ES 100w*5 ch Pro-Logic II Multi-Channel Acoustic Calibration System Set-up DTS NEO6 Head phone surround Dolby Digital Yes Dolby Digital EX Yes Dolby Pro Logic Yes Dolby Pro Logic II Yes DTS Yes DTS-ES Matrix 6.1 Yes DTS Neo: 6 Yes Surround Modes Advanced MUSIC, Advanced MOVIE, Expanded Theater, Virtual surround back, Sports Surround, Phones Surround, Game Mode, TV Surround Mode, 6-Channel Stereo, Advanced Surround: 7 + 1 Power output per channel 120 W Rated Power Output 100 W + 100 W DIN1 kHz, 1,00 %, 8 Ohm Input (Sensitivity/Imp.): LINE 200 mV / 47 kOhm Frequency Response: LINE 5 - 100.000 Hz, +0 / -3 dB Signal-to-Noise Ratio: LINE (DIN) 88 / 64 dB Dimensions (W x H x D) 420 x 158 x 401 mm Pioneer Hybrid Amplification Yes Digital Signal Processor Motorola 150 MIPS 48-bit Processing D/A Converter 96 kHZ/24-Bit A/D Converter 96 kHz/24-Bit (2-channel) Radio Data System (RDS) Yes Random Preset Stations 30 Usable Sensitivity (Mono) 13,2 dBf, IHF (1,3 µV / 75 Ohm) Sensitivity Mono 1,1 µV Sensitivity Stereo 50 µV Signal-to-Noise Ratio Mono (DIN) 62 dB Signal-to-Noise Ratio Stereo (DIN) 58 dB Stereo Separation at 1 kHz 40 dB Multi-Channel Input 5.1 ch (DVD) Digital Audio Input 3 (assign) Digital Coaxial Input 2 Digital Optical Input 1 Digital Audio Output (Optical) 1 Audio/Video Output 1A / 1AV+1V Pre-amp Output Yes (SW / SB) A/V Input on Front Yes Speaker A/B Independent Quick Set-up Room 3 + Position 3 Midnight Listening Mode Yes Bass/Treble Tone Controls Yes Loudness Yes Input (Sensitivity/Impedance) 1 V p-p / 75 Ohm Type Preset Source Control DVD, Satellite tuner, MCD, DTV control Sleep Timer Yes
Κωνσταντίνος Παντός
