Pioneer - Deh-4700mp
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Key features DEH-4700MP
Negative LCD display
White display illumination
Green/blue key illumination
Rotary volume control
Best station memory
Sound Level Adjustment
Cellular mute
ISO-connector ready
Features - General DEH-4700MP
CD Text Yes
Remote control Ready
Hard-wired remote input Yes
ISO Connector Yes
Display illumination LCD
Rotary volume Yes
Removable Front Panel Yes
Cellular telephone auto muting Yes
Flexible angle installation 0-60°
Features - Tuner DEH-4700MP
Adaptive RDS (PI, PS, AF, TP/TA) Yes
ARC FM D4Q
BSA (Best TP Station Auto Search) Yes
High speed PLL Synthesiser tuner Yes
PNS (Pulse Noise Suppressor) Yes
No. of Presets 18
BSM (Best Stations Memory) Yes
Features - CD player DEH-4700MP
Oversampling digital filter 8x
D/A Converter 1- Bit
Fast forward/reverse Yes/Yes
Track Search/Scan/Repeat Yes/Yes/Yes
Track/Manual search Yes/Yes
Random Play Yes
Last position memory Yes
CD Text Yes
CD-R Playback Yes
CD-RW Playback Yes
Features - Audio / Amplifier DEH-4700MP
Max. output power (watts) MOSFET 4 x 50 Watt
DIN output power (DIN45324, +B=14.4 V) 4 x 27 Watt
EEQ Yes
5-mode preset equaliser Yes
Custom preset equaliser Yes
3-band parametric equaliser Yes
Selectable Loudness Yes
Selectable FIE (Front Image Enhancer) Yes
Loudness Yes
Source level adjuster Yes
Fader Yes
RCA Preout 1
Specifications - FM DEH-4700MP
Frequency range 87,5 - 108 MHz
Usable sensitivity (75 ohms) 8 (0,7) dBf/µV
S/N ratio 75 dB
Frequency response 30 - 15.000 Hz
Stereo separation 45 dB
Specifications - MW DEH-4700MP
Frequency range 531 - 1.602 kHz
Usable sensitivity 18 µV
Specifications - LW DEH-4700MP
Frequency range 153 - 281 kHz
Usable sensitivity 30 µV
Specifications - CD DEH-4700MP
Frequency response 5 - 20.000 Hz
S/N ratio 94 dB/1 kHz
Dynamic range 92 dB/1 kHz
Specifications - General DEH-4700MP
Chassis size (W x H x D) 178 x 50 x 157 mm
n_olympios
Μαντιναδόρος!
Ομορφο, αλλά έβαλαν πάλι την ίδια οθόνη...
Πάντως το βουρτσισμένο αλουμίνιο δείχνει πάντα πολύ καλό.
Tα νέα JVC που κατέβασα τα είδες?
Υπάρχουν πολλά μοντέλα και με καλές προδιαγραφές!!!
Αξίζουν μια καλή ματιά!!! :roll: :wink:
ευτυχως το διορθωσες αυτο το 129 γιατι ειμασταν στα ορια του εγκεφαλικου.
ενταξει 159 εινια νορμαλ τιμη για μη intersys pioneer...
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
αναγνώρισε αμέσως το CD-R δισκάκι με τα mp3, βρήκε τους φακέλους με τα τραγούδια και η προσπέλαση από φάκελο σε φάκελο είναι ταχύτατη...
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
ο ενσωματωμένος ενισχυτής δεν είναι κανένα κτήνος αλλά ανεβάζει ικανοποιητικές στάθμες, ενώ ο ραδιοφωνικός δέκτης είναι αρκετά ευαίσθητος...
Συγκρινόμενος με τα ίδια ηχεία (JBL GTO 605Ce) με τα οικονομικά μοντέλα της (JVC CD KD-G151 και CD KD-G312) που είχαμε πρόχειρα όταν κάναμε την εγκατάσταση είχε περισσότερη ατάκα και πιο μαλακά πρίμα (τα JVC και ιδίως το 151 είχαν πολύ έντονα συριστικά αλλά και φοβερή λαμπρότητα)
Συνολικά και δεδομένου της πολύ χαμηλής τιμής (μόνο 123€!!!) θα έλεγα ότι είναι το best buy των ραδιο-cd της οικονομικής κατηγορίας. Τα μοναδικά που δεν έχω ακούσει μέχρι τώρα για να είμαι απόλυτος είναι τα νέα Clarion και τα VDO...
κτηνος δεν ειναι αλλα λογω mosfet δειχνει να οδηγει με λιγοτερα προβληματα τα ηχειακια. οι παλιοτεροι ενισχυτες οταν επρεπε να βγαλουν λιγο μπασσο (λιγο ρευμα δηλαδη) τα γ@... μπερδευαν ολα και ουσιαστικα ηταν σα να ειχαν τη μιση ισχυ...
Άντε ντεεεε.......
Τα κατάφερες!!!
Καλές ακροάσεις Σπύρο..........
Μην βιαστείς για νέο υλικό (πίσω ηχεία πχ κ.ο.κ.)
Άκουσέ το όπως είναι τώρα, και όταν αρχίσεις να το συνηθίζεις, ξανασυζητάμε τι άλλο μπορείς να κάνεις......... :roll: :wink:
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
λοιπόν χθες πήγα με το αμάξι σε όποιο λακουβόδρομο ήξερα για να δω αν πηδάει η κεφαλή ανάγνωσεις στις λακούβες...
Δεν πήδηξε ούτε μία φορά!!!
αφου τα ειπαμε ρε (και απο δω και απο την αλλη μερια)
ΠΙΟΝΕΡΑΡΑ ΡΕΕΕΕΕΕΕΕΕ!!!!
Katerinanota
