Pioneer DVR-630H-S
Πωλείται το εν λόγω DVD recorder σχεδόν αχρησιμοποίητο.
Χαρακτηριστικά:
Digital audio output sockets: Optical (toslink) Analogue audio output sockets: Stereo via 2 x RCA/phono Video in/output sockets: Front panel: DV input (IEEE1394/Firewire/i.LINK), S-Video, composite video and stereo audio in,
Component video output (supports PAL & NTSC Progressive Scan)
Scart 1: RGB, S-Video, composite video and stereo audio out
Scart 2: RGB, S-Video, composite video and stereo audio in & out
Video loop: S-Video (din), composite video (RCA/phono), stereo audio (2 x RCA/phonos) in and outputs
Antenna in and output with RF loop-through, control in minijack socket, G-link socket Playback format compatibility: DVD/-R/-RW/+R/+RW, CD/-R/-RW, MP3, WMA, VCD, SVCD, JPEG, Kodak Picture CD Record format compatibility: Dual layer DVD-R, DVD-R/RW Hard disk: 250GB hard disk built in Edit functions: One-touch copying (from DVD to HD or HD to DVD), non-linear editing options (divide, combine, move tracks), name: disc/track, erase: track/disk/A-B, with preview-before-action facility, "disc backup" - creates a backup of an existing disc by first transferring all data onto HD and then onto a blank disc, sort titles by user-defined genre, add thumbnails to titles for easy disc navigation, title lock (prevents accidental erasure or editing of valuable recordings), three-step undo Playback functions: Cursor style navigation on remote handset, disc navigator thumbnail driven programme finder, slow motion, frame back/forward, A-B repeat, programme play, "jukebox" mode allows you to copy up to 999 albums onto the HD from CDs and then use the unit as a non-stop music source, dictating the order or tracks played by genre, date added, most listened, album name etc, JPEG photo viewer with slideshow and image rotate/zoom features.
Three user-definable image setting presets or manual adjustments of white level, black level, gamma, hue, chroma.
Dynamic range control, to deliver audible movies at low volume levels without large peaks and troughs in the volume level Record functions: Simultaneous record and playback, chase play (watch from the start of a programme whilst the end is still being recorded) Timer: 32 event, 1 month with Video+, daily and weekly record features, automatic optimisation to adjust video quality if a programme wont fit on the remaining disc space available or, if the disc runs out timer automatically uses available hard disk space, auto-replace recording: records over scheduled, regular programmes - such as soap operas - with every new transmission Tuner: PAL-I, NICAM Digital Stereo sound reception Record time: 8.5 GB dual layer DVD-R disc:
Format XP SP LP EP SLP SEP MN1 Time (mins) 111 215 431 646 861 897 1440 250GB Hard Disk:
Format XP+ XP SP LP EP SLP SEP MN1 Time (hours) 36 53 106 212 319 425 532 711 Copy/transfer features: Up to 60x high speed dubbing from HD>DVD Digital audio format outputs: Dolby Digital, DTS, PCM, MPEG Built in audio decoder: No Video standards: PAL/NTSC source playback Supplied accessories: Remote control, batteries, antenna fly lead, Guideplus cable (for use with compatible satellite receivers) W x H x D (mm): 420 x 59 x 273 Weight (kg): 4.1 Finish: Silver Extra: Guideplus EPG: A free, interactive, 7 Day Ahead on-screen TV programme guide which provides now/next functionality, one-touch recording and timer setting, genre search, programme recommendations based on your stated preferences and profile. TV auto power on, switching and "Direct TV" recording (records whatever programme is on the TV as you watch it, also compatible with other manufacturer's Scart connection features such as "AV Link", "T-V Link", "EasyLink", "MegaLogic", "SMARTLINK", "Q-Link", "DATA LOGIC", "NexTView Link". Automatically downloads channel presets, TV type etc from many televisions or automatic setup from received signal. *Not all edit functions available for all disc types
Τιμή: 350€
costasgera
