Pioneer PDP-5045HD Plasma TV
Κώστας Φ.
Plasma Display Specifications
Screen Size 50" diagonal
Screen Aspect 16:9
Contrast Ratio [not published]
Brightness 1000cd/m2
Pixel Pitch 0.808mm x 0.858mm
hSync 15.625 - 45.0 kHz
vSync 45.0 - 84.997 Hz
Color System NTSC, ATSC
Data Signals VGA, SVGA, XGA, WXGA
TV Scan Lines 480i, 480p, 720p, 1080i
Input Terminals
Composite Video 3 (RCA)
S-Video 3 (4-pin mini DIN)
Component Video 2 (RCA x 3)
VGA RGB Signal 1 (15-pin mini d-Sub)
HDMI Interface 2
Serial Control (RS232C) 1 (9-pin mini d-Sub)
Output Terminals
Composite Video 1 (RCA)
S-Video 1 (4-pin mini DIN)
Digital Audio 1 (OPTI)
Plasma Monitor Accessories
Audio Amplifier 13W x 2
Speakers Built In Speakers
Mounting Options Table Stand Included
Also Included:
Media Receiver, Speakers, Swivel Stand, Smart Remote And 3 Meter Digital Connection
Dimensions and General Specs.
Power Supply 100-120V @ 50-60Hz
Power Consumption [not published]
Dimensions 50” x 29” x 3 7/8”
Weight 83.82 lbs.
FCC Class FCC Class B, Home Use
Key Features of the Pioneer PDP-5045HD 50" Plasma Monitor
50" Pioneer Plasma TV, Full HDTV Resolution (1280 x 768p)
16:9 Aspect Ratio
Advanced PureCinema with 3:3 Pull Down
First Plasma Capable of 72 Hz Display
ACE II - Over 1 Billion Colors
Ultra Bright, 1,000 cd/m2
Deep Encased Cell Structure with Black Stripe Coating
Adjustable Color Temperature, 3 Settings w/ 6500 Degrees
Multi Picture Window P-I-P or Split Screen (NTSC, HDTV, PC)
Dual HDMI Connections
IEEE-1394 Digital Interface
Component RGB with BNC Connectors
Integrated NTSC and ATSC Tuners
3 Dimensional Y/C Separation
Includes: Plasma Panel, Media Receiver, Speakers, Swivel Stand, Smart Remote and 3M digital cable
Inputs:
Antenna Input, VHF x 3 (75 ohms unbalanced F connector)
A/V Input (Front) x 1 (RCA Pin)
A/V Input (Rear) x 3 (RCA Pin)
S-Video Input (Front) x 1
S-Video Input (Rear) x 2
S-Video Output (Rear) x 1
Component Input (Front) x 1
Component Input (Rear) x 2
D-Sub 15 Input (Front) x 1 (for PC Input)
Digital Audio Output (Rear), Optical
i.LINK, 2 Terminals
HDMI Input, 2 with HDCP
Display Dimensions: 50" x 29" x 3-7/8"
Display Weight: 83 lbs., 13 oz.
Media Receiver Dimensions: 16 9.16" x 3 9.16" x 11 11.16"
Media Receiver Weight: 12 lbs., 9 oz.
One Year Warranty (Residential Application Only)
Πηγή: plasmatvbuyingguide.com
tazman71
