PIONEER SA-800+TX-800
Ev 8848
Προς πώληση τό σετ σέ άριστη κατάσταση.
Τιμή πώλησης μόνο 450 ευρώ.
Για άμεση επικοινωνία τηλ 6974273622
Specifications
Power output: 26 watts per channel into 8Ω (stereo)
Frequency response: 20Hz to 60kHz
Total harmonic distortion: 0.5%
Damping factor: 65
Input sensitivity: 2.3mV (mic), 0.11mV (MC), 3mV (MM), 56mV (ceramic), 230mV (line)
Signal to noise ratio: 80dB (MM), 100dB (line)
Output: 230mV (line), 35mV (DIN), 3V (Pre out)
Speaker load impedance: 4Ω to 16Ω
Semiconductors: 2 x FET, 35 x transistors, 20 x diodes
Dimensions: 430 x 145 x 337mm
Weight: 10.3kg
Specifications
Type: Mono/Stereo Tuner
Tuning Bands: FM, MW
Tuning Scale: Analogue
FM Tuning Range: 88 to 108 MHz
MW Tuning Range: 525 to 1605 kHz
Sensitivity: 1.8uV (FM), 10uV (MW)
Signal to Noise Ratio: 70dB (FM), 50dB (MW)
Distortion: 0.5% (FM)
Selectivity: 70dB (FM), 30dB (MW)
Output: 2400mV
Semiconductors: 2 x FET, 4 x IC, 29 x transistors, 18 x diodes
Dimensions: 430 x 145 x 345mm
Weight: 7.3kg
bmavroeidis
