Pioneer SC-LX73
Πωλείται ο Pioneer SC-LX73 AV Receiver σε άριστη κατάσταση μαζί με το manual, το (φωτιζόμενο και προγραμματιζόμενο) τηλεκοντρόλ και το μικρόφωνο ρύθμισης του. Tηλ. Επικοινωνιας 6976334707
ειμαι απο πατρα δεκτος καθε ελεγχος
Τιμη 300ευρω
. 178992854_502107057837097_328294861438470666_n.jpg 179043838_792246888064501_4529269704444294685_n.jpg 179279743_4091983374217675_6890975928226227735_n.jpg
The Pioneer SC-LX73 AV Receiver is ideally suited for the audiophile who accepts no compromise in quality whatsoever. With the Pioneer SCLX73, Pioneer has made it clear to focus on The SC-LX73's performance and construction with this audio visual receiver. The Pioneer SC-LX 73 uses ICE power - Direct Energy HD, an extremely efficient type of amplification, capable of delivering overwhelming power and fast response, it features analogue feedback loops to ensure the signal is free of distortion or interference. The result, unrivalled sound quality.
During the development process of each Air certified product, extensive tuning sessions take place to ensure that the audio playback is so accurate that it would be suitable as a studio-grade monitoring device. Available to download from the Apple App store for free, the Pioneer SC-LX73 can be controlled via intuitive touch screen menus on any iPhone or iPod touch.
The Pioneer SCLX73's MCACC auto calibration system automatically optimises many aspects of the AV Receivers sound settings (using an included microphone) based on the positioning of connected speakers and acoustics of the room environment.
The SC-LX73 also features PQLS Multi-Channel. PQLS is a jitter reduction system that improves the coherence, timing and soundstage of audio playback, it stands for Precision Quartz Lock System. This feature caters for jitter-less multi-channel playback over the HDMI interface.
140 Watts per channel
HDMI v1.4 with 3D
Air Studios sound tuning
Pioneer iControl
PQLS Multi-Channel
Specifications
Main FeaturesSC-LX73
Input & Output connectionsSC-LX73
Apple CompatibilitySC-LX73
Surround Sound FormatsSC-LX73
Audio FeaturesSC-LX73
Video FeaturesSC-LX73
Power OutputSC-LX73
ConstructionSC-LX73
Amplifier SpecificationsSC-LX73
Output Power per Channel180 W
Impedance at Output Level
Number of Channels7
Signal / Noise Ratio103 dB
Input Connectionsβ’ 6 x HDMI (1080p upscaling) (1 Front Input)
β’ 4 x Composite In
β’ 3 x Component In
β’ 2 x Coaxial In
β’ 3 x Optical In
β’ 1 x USB / iPod/iPhone
β’ 1 x Ethernet
β’ 1 x Bluetooth adapter port for AS-BT100 (included)
Output Connectionsβ’ 2 x HDMI
β’ 1 x Composite
β’ 1 x Component
β’ 1 x Optical
AM/FM Tuner with RDSYes
Tuner Pre-set Stations63
HD Audio FormatsDolby TrueHD, DTS-HD Master Audio, DTS-HD High Resolution
Audio Return ChannelYes
Control with HDMIYes
HDMI RepeaterYes
On-Screen Display (GUI)Easy-to-use GUI, available in English, French, Italian, German, Spanish, Dutch and Russian
Internet RadioYes
Remote ControlGlow-key, preset remote control (learning)
RF RemoteOptional
Weight18,5 kg
Dimensions (W x H x D)420 x 200 x 460 mm
AV Front InputYes
Bi-AmplifierYes
Bluetooth Adapter PortYes
Component Video Input/Output3/1 (assignable)
Composite Input/Output4/1
Digital Optical Input/Output3/1 (assignable)
Digital Coaxial Input/Output2/- (assignable)
Ethernet1
HDMI Input/Output6 (assignable)/2
HeadphoneYes
IR In/Out2 in / 1 out
Large speaker terminalsYes
Pre-amp OutputYes (SW)
Speaker A/BYes
USB Host (Front)Yes
Works with iPodYes, via digital direct USB connection (included)
Works with iPhoneYes
iControlAVYes
iPhone Control ButtonYes
Compatible Generations5th Generation, Nano and above, iPhone (including 3G)
Supported FunctionsAudio & Video (Video with the supplied iPod/iPhone Video + USB Audio cable), On-Screen Album Art
Dolby DigitalYes
Dolby Digital EXYes
Dolby Digital PlusYes
Dolby Pro Logic IIYes
Dolby Pro Logic IIxYes
Dolby Pro Logic IIzYes
Dolby True HDYes
DTSYes
DTS-ESYes
DTS Neo: 6Yes
DTS 96/24Yes
DTS-ExpressYes
DTS-HD High Resolution AudioYes
DTS-HD Master AudioYes
WMA 9 ProYes
THX CertifiedYes
DTS Neural SurroundYes
Surround Modes13 + 1 (Action, Drama, Sci-Fi, Mono Film, Entertainment Show, Expanded Theater, TV Surround, Advanced Game, Sports, Classical, Rock/Pop, Unplugged, Extended Stereo + Phones Surround)
Auto Level ControlYes (Multi-channel)
Auto SurroundYes
Bass/Treble Tone ControlsYes
Dialogue EnhancementYes
Digital Noise ReductionYes
Dynamic Range ControlYes
Front Stage Surround AdvanceYes
Jitter ReductionYes
LoudnessYes
Midnight Listening ModeYes
Multizone FunctionYes (3)
Phase ControlYes
MCACCYes (Advanced, 9-band)
PQLSYes (Multi-channel )
Sound Delay (LipSync)Yes
Advanced Sound RetrieverYes (Multi-channel)
Sound Retriever AIRYes
Standing Wave ControlYes
Stream DirectYes
Symmetric EQYes
Virtual Surround BackYes
X-CurveYes
Deep ColourYes
3D ReadyYes
x.v.ColourYes
HD Digital Film Direct 24Yes
Power output per channel180W
Condition1kHz, 1% THD, 6Ω
Rated Power Output180W per channel
Input (Sensitivity/Imp.): LINE400 mV / 47 kΩ
Frequency Response: LINE5 Hz - 100 kHz +0/-3 dB
Signal-to-Noise Ratio: LINE (DIN)103 dB
Power RequirementsAC 220 - 230 V / 50/60 Hz
Power Consumption (in use / standby)330 W / 0.30 W
AIR Studio Sound TuningYes
ICEpowerYes
Pioneer Hybrid AmplificationYes
Digital Signal ProcessorFreescale
Direct Energy HD amplifierYes
Front L & R Bi-Amplifier FunctionYes
D/A Converter192 kHz / 24-bit
A/D Converter192 kHz / 24-bit
Ο ενισχυτης δόθηκε. Ευχαριστώ το φόρουμ για την φιλοξενία.
Παρακαλώ να κλείσει!
albie
