Προς πώληση σέ άριστη κατάσταση, προσωπική συλλογή.
Τιμή πώλησης 500 ευρώ.
Για άμεση επικοινωνία τηλ 6974273622.
Description
The SX-780 features a high output, low distortion power amplifier, a high fidelity equaliser amplifier with low noise and high gain, a high stability tuner section, tone controls with tone defeat function, built in protection circuits and independent power meters.
Specifications
Tuning range: FM, MW
Power output: 45 watts per channel into 8Ω (stereo)
Frequency response: 5Hz to 80kHz
Total harmonic distortion: 0.05%
Damping factor: 30
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 76dB (MM), 95dB (line)
Output: 150mV (line)
Speaker load impedance: 4Ω (minimum)
Semiconductors: 5 x FWT, 11 x IC, 26 x transistors, 22 x diodes
Dimensions: 480 x 140 x 320mm
Weight: 11.2kg
Description
Specifications
Damping factor: 30
Weight: 11.2kg
163,5 KB Προβολές: 0
163,4 KB Προβολές: 0
276,5 KB Προβολές: 0
158,3 KB Προβολές: 0
