"The active VM-50, VM-70, and VM-80 units produce clear audio with fast-attacking, punchy bass. And, thanks to flexible DSP settings, the speakers can be tuned to suit the characteristics of a room, making them perfect for recreating a club sound when you’re DJing or providing a flat frequency response when you’re producing music in a home or professional studio setting.
- High-quality components
- Aramid fiber woofer cones and Vortex Bass Accelerator
The Vortex Bass Accelerator also ensures that low-end audio is tight and free from unwanted vibrations, as ribs in the bass reflex port mean that air flows freely from the speaker to deliver pure sound – whether you’re listening to vocals or instrumentals.
- Constant directivity horn
The VM series speakers are voiced flat to ensure you hear the natural sound of the music. But every room reacts differently to audio waves. To help you tweak the output and find the sound that’s perfect for the room you’re working in, each VM speaker includes DSP setting.
Reach around to the back of the speakers and you’ll find 2 knobs: Low EQ and High EQ. Without needing to look at the rear panel, you can click the knobs into 4 different positions each, giving you 16 possible EQ settings that are simple to engage. Choose the one that sounds best for DJing or producing music in your home or studio, depending on the shape, size, and construction of the room. For example, if your speakers are positioned near to walls or if you’re working at night, you might want to minimize bass vibrations by switching the Low EQ to Room 1 mode. Or if you find that you’re not getting enough treble, you can boost the highest frequencies by switching the High EQ to Room 2 mode."
https://www.pioneerdj.com/en-us/news/2021/vm-series-active-monitor-speakers/
