PIONEER VSX-AX3
σε υπεραριστη κατασταση.7x100 watts ανα καναλι.
Key Features
Type Receiver
Number of Channels 7.1 Channels
Stereo Mode Power 100 Watt @ 8 ohm, 1 kHz, THD: 1%
Surround Mode Power 100 Watt @ 8 ohm, 1 kHz, THD: 1%
Surround Sound Dolby Digital® • DTS® • DTS ES® • THX EX® • Dolby Pro Logic II
THX Certification Select
DSP
DSP Modes 5 CH Stereo • 7 CH Stereo • Action • Chamber • Classical • Drama • Jazz • Mono Movie • Musical • Rock Concert • Sci-Fi • Theater • Virtual
Inputs / Outputs
Analog Inputs 7.1 Channels x 1
Preamp Outputs 7.1 Channels
Convenience
Speaker Selection A/B
Tuner Presets 30 Channels
Tone Controls Bass & Treble
On Screen Display With OSD
Remote Control
Remote Control Type Learning
Illuminated Remote Non-Illuminated
Design Keypad
Dimensions
Weight 18.27 kg
Height 18.8 cm
Width 42 cm
Depth 46.4 cm
Miscellaneous
Power Consumption 600 Watt
Πωλειται στα 350 ευρο
JGmag
