Polymer Audio Research. Χρυσός και διαμάντι.
Κώστας Φ.
Ή πως να ζητήσετε μία HiEndου σε γάμο (αν τη βρείτε). :happy_9:
What does a $12,350 midrange driver with a pure diamond diaphragm look like?
Pictures after the jump.
The Polymer Audio Research Polymer Logic Loudspeakers use one of the diamond cone midrange drivers (pictured above) per side in addition to a Supravox TG1 tweeter and a pair of hand made vapor deposited titanium cone woofers.
Polymer Research states that, "The diamond midrange cone in the Polymer Logic currently exists in only one commercially available loudspeaker system, the $250,000/pr Marten Design Coltrane Supreme." And don't think for a second that tweeter has gold paint on it, that is a titanium dome covered in a pure layer of solid gold.
"The Polymer Logic is clearly an astonishing value for $24,990/pr and contains more pure diamond and gold then you’ll find in any $500,000 diamond engagement ring."
The only thing missing from these speakers is a Leprechaun to guard the treasure.
According to Polymer Research the diamond midrange drivers are made one at a time in a plasma reactor and because of cones that often crack in the process, it usually takes about 6 weeks to make a pair of the drivers.
Specs:
  • Nominal impedance: 5 ohms (minimum impedance 4.1 ohms)
  • Woofer: Two 7" vapor deposited titanium
  • Midrange: One 2.5" diamond cone
  • Tweeter: One 1" gold coated titanium dome
  • Sensitivity: 91dB @ 1 watt (2.0V at 1 meter)
  • Minimum amplifier power: 12 WPC
  • Frequency response: 30Hz – 40kHz
  • System weight: 285 lbs each tower
  • Approximate shipping weight: 820 lbs for complete system
  • Height: 48.75” (including supplied supports)
  • Width: 13”
  • Depth: 15”
  • Price: $24,990/pr
audiojunkies.com
Manosahead
