Mr Spock
demokratischer - sektor
It has been nearly a decade since PrimaLuna has introduced an entirely refreshed product line and PrimaLuna fans will find the new EVO series shares the previous line’s DNA. The new products feature upgraded transformers and internal components, improved aesthetics (rounded faceplate edges, Roll-Top tube cages on all models, etc) and an enhanced features set including headphone amplifiers on all integrated amplifiers and true-balanced, transformer-coupled XLR inputs and outputs on upper-end models. Just as importantly is what hasn’t changed, including the metculous hand-assembly, point-to-point wiring, superlative build quality and cutting-edge Adaptive Auto-Bias (TM) circuitry upon which PrimaLuna has built its reputation.
http://www.theabsolutesound.com/articles/primaluna-evo-series-debuts-at-axpona/
EVO 400 Integrated Specifications
Power
Ultra-linear 70 watts x 2 (EL34)
(8Ω, 1% THD)
Power
Triode 38 watts x 2 (EL34)
(8Ω, 1% THD)
Inputs 5x Stereo RCA
Stereo RCA HT Bypass
Outputs 4 & 8 Ω
RCA Stereo/Mono Subwoofer
Stereo RCA Tape Out
1/4" Headphone
Freq. Response 9Hz-50kHz +/- 1dB
8Hz-68kHz +/- 3dB
THD < 0.1% @ 1W
< 2% @ Rated Power
S/N Ratio 93 dB, 93 dbA
Input Sensitivity 320 mV (EL34)
Input Impedance 100kΩ
Power Consumption 255 watts
Standard Tube Complement 6 - 12AU7
8 - EL34
Dimensions (WxHxD) 15.2" x 8.1" x 15.9"
Weight 68.2 lbs
https://www.primaluna-usa.com/primaluna-evo-400-tube-integrated
Power
(8Ω, 1% THD)
Power
(8Ω, 1% THD)
Outputs 4 & 8 Ω
Stereo RCA Tape Out
1/4" Headphone
8Hz-68kHz +/- 3dB
THD < 0.1% @ 1W
< 2% @ Rated Power
8 - EL34
Weight 68.2 lbs
