m1ts0s
News poster
The company’s 40 years of experience now culminate in the Héritage3: an active floor-standing speaker newly developed for the living room. While the Héritage3 was specifically designed for home use from the ground up, the engineers were able to draw on the expertise gained from developing the renowned three-way studio monitor speaker Héritage3. The result is high-end professional level sound for discerning music enthusiasts. The DSP-free, completely analogue circuitry is combined with an enclosure design featuring 45-degree angles to reduce secondary emissions and achieve a perfectly flat frequency response within 1 dB across the entire spectrum.
Inside the wooden housing of the PSI Audio Héritage3 is proprietary technology – the very same technology that has gained the trust of professional music producers and sound engineers worldwide. Woofer and midrange driver employ the extremely efficient Class G/H topology amplifiers, providing more power with less distortion. The phase response is just as linear as the frequency response due to PSI Audio CPR technology (Compensated Phase Response). The reproduction of rapid transients is perfected through AOI, the Adaptive Output Impedance, continually monitoring the membrane movement and feeding it back into the amplifier. The result is sonic accuracy at its finest.
The PSI Audio Héritage3 features three drivers: the 10-inch woofer for exact bass, the 5.8-inch midrange driver for transparent mids and the entirely handmade 1-inch dome tweeter for airy highs. The amplifiers drive them with more than sufficient power: 170 W for the woofer, 80 W for the medium range and 50 W for the tweeter, resulting in a total continuous maximum SPL of 109 dB for a single speaker. The spectrum ranges from 28 Hz to 23,000 Hz at 1 dB tolerance.
https://www.psiaudio.swiss/event/heritage3-presented-at-high-end-munich/
