QSC Cinema Series DCA1622 Τελικός Ενισχυτής Class AB 2x 350W RMS /8Ohms
FEATURES
  • Active Inrush Limiting - won't blow circuit breakers at turn-on (a QSC cinema exclusive!)
  • Both speaker and monitor panel outputs (a QSC cinema exclusive!)
  • Exclusive PowerLight power supply for great bass (a QSC cinema exclusive!)
  • A hum-free noise floor and ultra-low distortion
  • Only 3.5 inches high; even the most powerful systems can be built with only one rack
  • DataPort interface for DCP Digital Cinema Processors and DCM Digital Cinema Monitors - a QSC cinema exclusive!
  • Patented Output Averaging™ short circuit protection
  • 14-inch deep - works with standard depth racks for lower cost and less floor space
  • Only 21 pounds, for easier racking and shipping - no need to remove amps from pre-wired systems before shipping
  • Gain control security cover protects amp against tampering and misadjustment
  • Variable-speed fan cooling and back-to-front air flow
  • Neutrik Speakon® and safety-shrouded barrier strip output connectors
  • LED indicators for metering, status, and operating mode (a QSC cinema exclusive!)
Σε άριστη κατάσταση, στα 350 ευρώ. Ανατολική Αττική.
Θα κρατηθεί για την ώρα.
Παρακαλώ να κλείσει.
Ευχαριστώ για τη φιλοξενία.
wendigo
