m1ts0s
News poster
The Razer Blade Stealth Ultrabook™ sets the new standard for ultra-mobility and extreme performance. The incredibly thin 0.52” CNC aluminum chassis encases an Intel® Core™ i7 processor, and the most visually stunning 12.5” high-resolution touch display.
For extreme performance, the Blade Stealth fuses seamlessly with the Razer Core via Thunderbolt™ 3, delivering external desktop graphics and expanded connectivity.
The 12.5” Razer Blade Stealth’s breathtaking display is available in two high resolutions: Ultra HD at 3840 x 2160 pixels and Quad HD at 2560 x 1440 pixels. Both IGZO (Indium Gallium Zinc Oxide) displays are touch-enabled with wide viewing angles and high-color saturation to provide unmatched color and image quality.
Experience amazing color saturation with the UHD display featuring 100% Adobe RGB color space coverage. Images are bright and clearly visible with wide viewing angles of up to 170°. Whether editing content or sharing a presentation, the Razer Blade Stealth was designed for ultimate visual clarity.
With the Razer Blade Stealth’s extremely thin and light design, you’d never guess it holds all that power. The 6th Gen Intel Core i7-6500U processor gives the Razer Blade Stealth 2.5GHz of processing power and Turbo Boost speeds up to 3.1GHz. Push even more pixels with the Intel® HD Graphics 520 for smooth visuals.
The Razer Blade Stealth also packs up to 512GB of PCIe solid-state storage and 8GB of fast dual-channel memory, allowing you to boot quicker and launch applications faster than ever before.
Razer Core
EXTERNAL DESKTOP GRAPHICS
The Razer Core is the world’s first true plug and play Thunderbolt™ 3 (USB-C) external graphics enclosure, allowing you to transform your notebook into a desktop gaming experience. Featuring plug and play support with compatible graphics cards, you won’t need to reboot your system every time you connect your Razer Blade Stealth to Razer Core. Connect to the future with the most advanced and versatile external desktop graphics solution available.
Easily upgrade or customize your preferred level of performance with support for full-length, double-wide PCIe desktop graphics cards (sold separately) for a level of performance that fits your play style.
With the ability to connect gaming peripherals to Razer Core’s additional I/O ports, you can easily transform your Razer Blade Stealth into a full gaming setup.
Complete with 4 USB 3.0 ports and Ethernet, the Razer Core makes it incredibly easy for you to connect all your devices. By using a single USB-C connection to your notebook, this stellar graphics dock provides you with both data transfer and notebook charging without any hassle.
http://www.razerzone.com/gaming-systems/razer-blade-stealth
