Red Wine Audio Isabella
Κώστας Φ.
The pricing is $4000 for the Isabella, $5,500 with the inbuilt DAC. "The pricing is higher than I was initially aiming for but I'm very confident that the Isabella competes with the finest sounding preamps regardless of price. The build-in non-oversampling DAC option is also stunning. Very "non-digital" sound and with the USB-direct-to-I²S interface, the DAC is a sweet dream for anyone with a music server such as a MacBook. Here are more Isabella details:
  • 3 analog inputs, 2 analog outputs
  • optional built-in DAC features USB, coax (via 75-ohm high-bandwidth BNC) and Toslink optical with a discrete active output stage sans opamps)
  • the entire circuit runs of off SLA battery power (no dc/dc converters, no transformers, no rectifiers)
  • separate voltage regulation stages for B+, tube heaters, input select relays and optional DAC
  • adjustable gain switch for 6dB or 12dB gain
  • toggle switch to select between pure SLA battery operation or AC power for non-critical listening (charging the SLA batteries and playing via the AC power can happen simultaneously)
  • new remote volume control stepped attenuator board - more details about this soon
  • high-quality Vampire PCB-mount RCA jacks and 75-ohm BNC jack
  • SMART board and touch-sensing power on/off switch with built-in LED as featured in our Signature 30.2 and 70.2 amplifiers
  • matching size and aesthetic of our Signature 30.2 and 70.2 amplifiers
  • rapid-speed SLA battery charger with universal input voltage (100 - 240Vac, 50/60Hz) and IEC power input jack and output cable featuring a heavy-duty XLR plug
  • sliding clear window on the top of the unit for easy access to tubes (no need to remove the top cover for tube rolling).
  • Accepted tubes include: 6922/E88CC, 6DJ8/ECC88, 7308/E188CC, 7DJ8/PCC88, 6N23, 6H23, 6N11. Included stock tubes are 6922/E88CC, one per channel."
Περισσότερα: 6moons.com
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Απάντηση: Red Wine Audio Isabella
έλεος!!!
4000$ 1 κουτί, για 2 λάμπες, μερικές αντιστάσεις και πυκνωτές, και έναν εξασθενητή τύπου σκάλας???
Πάνε καλά???
Gebreselassie
Μαύρος!
Πόσο έπρεπε να είχε μωρέ κι εσύ, 100€?
Άσε που αν αυτές είναι τιμές καταλόγου, αυτό μπορεί να παίζει street price κάτω από 3.000$. Φυσιολογική τιμή, με την προϋπόθεση ότι παίζει και καλά βέβαια.
Ημίθεος
Ήθελα να ήξερα προς τι οι τιμές καταλόγου, αφού δεν τις πληρώνει κανένας. Μήπως μόνο για ψυχολογικούς λόγους, όπως κάνουν όλοι ανεξαιρέτως οι οπτικοί;
papaevagelouv
