Redgum
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Ολλάνδική εταιρία με ιδιοτροπίες...Άκου κλειδί στον ενισχυτή!!!
REDGUM RGi35 Integrated AmplifierPower Output: 35 + 35 watt/Ch RMS into 8ohms
continuous sine wave at onset of clipping (90 + 90 W RMS - transient)
Harmonic Distortion: less than .009% (below Clipping)
Intermodulation Distortion: less than .005% (below Clipping)
Signal to noise: greater than 100db
Input Impedance: 10k ohms (matches 600 ohms - 50k ohms)
Slew Rate: greater than 65Volt / microsecond
Damping Factor: greater than 150
Frequency Response: 0.8 Hz to 80KHz (-3db points)
Peak Current: greater than 120 amps
Audio Inputs: CD1, AV1, DVD, CD2, AV2
Suggested Speakers: REDGUM RGSB Bookshelf Speakers
Cabinet Finish: high gloss solid Red Gum wood fascia, black gloss thick steel chassis
Options: choice of dual or single volume; key switch, rocker or toggle switch; alternative front panels can made to order (at additional charge) or as supplied by customer; Other possibilities? just talk to us about it!
Warranty: Full 7 year Warranty
Dimensions: 420mm (W) x 360mm (D) x 95mm (H) 16.5in (W) x 14.2in (D) x 3.75in (H)
Shipping weight: 9.3 kg (8.16 kg cubic) 20.5 lb (18 lb cubic)
ο ίδιος κυκλοφορεί και σε signature series με 50w ανά κανάλι
τιμή 850€ online (1100€ signature series)
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
REDGUM RGi60 Integrated Amplifier
Power Output: 60 + 60 watt/Ch RMS (132 + 132 W RMS - transient)
Suggested Speakers: REDGUM RGSB 'Manna' shielded Bookshelf or RGS 'Lucens' Floorstanding Speakers
Options: choice of dual or single volume; key switch, rocker or toggle switch; alternative front panels can made to order (at additional charge) or as supplied by customer; Other possibilities? Just talk to us about it!
Shipping weight: 9.4 kg / 20.7 lb (8.2 kg cubic)
ο ίδιος κυκλοφορεί και σε signature series με 75w ανά κανάλι
τιμή 1300€ online (1600€ signature series)
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
REDGUM RGi120 Integrated Amplifier
Power Output: 120 + 120 watt/Ch RMS (285 + 285 W RMS - transient)
Suggested Speakers: REDGUM RGS38i Floorstanding Speakers
Cabinet Finish: high gloss solid Red Gum wood fascia, gloss black thick steel chassis
Shipping weight: 10.4 kg / 22.9 lb (8.16 kg cubic)
ο ίδιος κυκλοφορεί και σε signature series με 155w ανά κανάλι
τιμή 1900€ online (2300€ signature series)
Ωραίο αυτό με το κλειδί το καταργούν στ' αυτοκίνητα και το βάζουν στους ενισχυτές για ON OFF Switch :mrgreen:
Πάντως είναι πολύ όμορφες κατασκευές κι απλές σαν υλοποιήσεις.
NIK DRAGON
