REDRAY 4K player
gkontoletas
trouble in my brain
Ανακοινώθηκε επίσημα και θα είναι διαθέσιμο στα τέλη Δεκεμβρίου με τιμή 1,450$.
The REDRAY PLAYER is the first plug-and-play friendly device capable of providing 4K content to 4K displays. REDRAY features the ability to play 4K files as well as upscale HD files to Ultra High-Definition resolution (4096 x 2160). REDRAY connects to 4K displays using 1x 1.4 HDMI output or 4x HDMI 1.3 outputs, with an additional HDMI output for 7.1 channel audio (for HD displays, REDRAY uses 1x HDMI 1.3 output). REDRAY also supports 3D playback at high frame rates (48-60fps) — more than twice that of traditional HD plug-and-play 3D devices. Use your REDRAY iPad app or included IR remote to control your REDRAY and connect to your content like never before.
To convert your HD or 4K content to REDRAY compatible .RED files, REDCINE-X PRO and the RRENCODE plugin are required. 1x RRENCODE license is included with each REDRAY purchase.
RESOLUTION: Up to 4096 x 2160 pixels, 2D or 3D
DIMENSIONS: 316 x 61mm x 260 mm ( 12.4 x 2.4 x 10.2″ )
WEIGHT: 5.9 Lbs
MATERIAL: Aluminium
OPERATING TEMPS: Zero to 40 C
STORAGE TEMPS: Minus 5 to 60C
BIT-DEPTH (COLOR): YCbCr 12-bit 4:2:2 or RGB 8-bit 4:4:4
COLORIMETRY: ITU-R BT.709
VIDEO FILE FORMAT: .RED (4K), .MP4 (1080p, 720p)
PLAYBACK FRAME RATES: 24, 25, 30, 48, 50, 60 fps
GENLOCK: RS170A Tri-level Sync
PROGRAM OUTPUT: 4K DCI, UltraHD, 1080p, 720p
MONITOR OUTPUT: 1080p, 720p
OUTPUT CONNECTORS : 4 x HDMI 1.4 (Program), 2 x HDMI 1.3 (Monitor and Audio)
NOTABLE FEATURES: Network based 4K 3D Playback System.
MEDIA SECURITY: REDCrypt™ digital media encryption
REMOTE CONTROL: IR, 802.11, Ethernet
DIGITAL MEDIA: Internet download, SDCard or USB-2 flash media
AUDIO FILE FORMAT: .RED (up to 7.1 Ch) .MP4 (Stereo)
AUDIO OUTPUT: Up to 7.1 channel LPCM, 24-bit 48Khz
STORAGE CAPACITY: 1TB Internal SATA Drive
POWER: 120 – 240V 50 – 60Hz A.C
http://www.red.com/store/products/r...ge&eBslide&utm_campaign=REDRAY_Launch
http://www.reduser.net/forum/showthread.php?90306-REDRAY-ODEMAX
PPG
Πίπιτζι
Απάντηση: REDRAY 4K player
Α ρε μανουλα μας βλεπω συντομα παλι να κανουμε πλανα για πολλα εξοδα!!!
PPG
Πίπιτζι
Ισως επειδη ειναι σε dollars??χιχιχι:105:
τωρα που το βλεπω.....οχι αναλογικες στην πλατη .....
ας το παρουν οι <αλλοι>
gkontoletas
trouble in my brain
ποιες αναλογικές;
οι ταινίες θα γυρίζονται ψηφιακά με τις 4Κ κάμερες της RED, τα αρχεία θα μετατρέπονται σε RED format και θα αναπαράγονται από το REDRAY player, δεν υπάρχει λόγος ύπαρξης αναλογικών εξόδων σε μια πλήρως ψηφιακή αλυσίδα....
Το μόνο που λείπει είναι μια έξοδος DP v1.2 που μπορεί να μεταφέρει περισσότερη πληροφορία από το HDMI v1.4, βέβαια πρέπει να βάλουν και αντίστοιχη είσοδο και στον 4Κ προβολέα που ετοιμάζουν.
ποιες αναλογικές;
:142:
:615:
ποιες αναλογικές;
ξεχασες την μαγικη λεξη
Ισοσταθμιση
που τρεχει εξωτερικα
τρινοβ και ετσι
εκει ακομα δεν εχει μπει hdmi
δεν μπορει να εισαι σουπερ ντουπερ ουα στην εικονα και να παιζεις χωρις την μαγικη λεξη
Μπορεις ?
Αν εισαι εισαι τσιπης......
και κατι ακομα
μεχρι να γινουν ολα αυτα πραξη υποχρεωτικη,(μονοδρομος)
θα μιλαμε οχι για 8Λ
αλλα για 16Ψ ............
μαλλον η τρινοβ θα πρεπει να βαλει hdmi για να πουλησει παραπανω ...
παρε παραδειγμα απο την datasat ...
μαλλον μεχρι να γινει αυτο , θα ζουμε (οταν μπορεσουμε) σαν εσενα
κρυφη πληγη............
απλα θα περιμενουμε να ερθει απο (ψηλα) (μεταξυ μας)
το προβολι του 4Κ
gkontoletas
trouble in my brain
Αργύρη συγνώμη αλλά αδυνατώ να σε παρακολουθήσω.... αν θες γράψε απλά να σε καταλάβουμε για να απαντήσουμε.
δεν νομίζω να πιστεύεις ότι: η μετατροπή ψηφιακού ήχου σε αναλογικό από το player, μετατροπή πάλι σε ψηφιακό από τον audio processor, ψηφιακή ισοστάθμιση και μετατροπή πάλι σε αναλογικό είναι ότι καλύτερο....
ποιες αναλογικές;
...δεν υπάρχει λόγος ύπαρξης αναλογικών εξόδων...
Κι ο Κεφάλας πώς θα βλέπει; :119:
ποσο πιο απλα
πηγη σε
προσεσορα με hdmi
μετα
δεν θα πας σε ξεχωριστη μοναδα ισoσταθμισης ,
εκει δεν θες (για την ωρα) αναλογικες ?
C . papadakis
