Rega R5
Κώστας Φ.
Σύντομο review των R5 της Rega, απο το ΑudioEnz.
Οι τιμές είναι σε δολλάρια Νέας Ζηλανδίας (2200 ΝΖD = 1200 Euro).
"The weight of expectation was considerably greater than the 12.5kg mass of the speakers themselves. However solid that felt as I manoeuvred the tall (810mm), maple veneered boxes into place (definitely hard work this reviewing lark).
Supplied in matched pairs, the R5s can be arranged with their 180mm side-firing bass drivers facing inwards or outwards, adding to the usual placement conundrum.
Those side-mounted bass drivers do help to keep the R5’s front panel both slim and relatively uncluttered. A classic Rega RR125 mid-bass driver sits above a neat little Rega silk-domed tweeter and right at the foot is a gigantic, front-facing port. An ideal hiding place for small animals I’d imagine.
In the end, the R5 story is typical Rega, but with a twist. Yes there’s the musical communication and drive you’d expect, but it it’s far more natural and civilised than the traditional Rega sound. These really are do-it-all speakers that leave the music to excite or relax. That’s rare at any price, but at $2,200 it makes the R5s something of a bargain.
So now comes the really hard work. Giving them back. It just seems easier to buy them. So perhaps I will."
Full Review: AudioEnz.com
DimAster
