Reimyo PAT-777 Single-Ended Power Amplifier
review
One of the most amazing Harmonix products ever„Ÿ-a single-ended power amp that truly fulfills the 300B promise! Delivers clean, articulate, fast trebles but with smooth transients. Assures exceptional bass control, and superb transparency. Function and effect far beyond its 7-watt power source. Performance better than any other single ended power amp using the 300B for output. The simplest and most effective power amp in its class, bar none!
Circuits: NON-NFB Class-A.
Tubes: 310A x 2 (or WE328A); WE300B x 2; 5R4WG x 1
Input Impedance: 100kƒΆO
Input Sensitivity: 200mVrms 8ƒΆO (at 1-Watt)
Max. Power Output: 7W + 7W (at 8ƒΆO)
Output Power Terminals: 2ƒΆO/ 4ƒΆO/ 8ƒΆO (WBT)
Frequency Response: 10Hz - 20kHz
S/N Ratio:
Better than 105dB (IHF-A Average rate)
Better than 87dB (FLAT Average rate)
Remaining Noise:
Better than 0.03mVrms (IHF-A Average rate)
Better than 0.23mVrms (FLAT Average rate)
Cross talk: Better than 90dB/1kHz (Average rate)
Power Consumption: 150Watt (Max rated at 7W)
Power Requirements: 117V or 220-230V, 50/60Hz
Body Construction: High quality aluminum
Dimensions: 430(W) x 225(H) x 385.5(D) mm
Weight: 25.0 Kgs Price:$21,995.00
Reimyo CAT-777 Vacuum Tube Control Amplifier
Type: Vacuum Tube Control Amplifier
Circuitry: NON-NFB. Complete Discrete Construction.
Tubes:
Output: 12AU7 x 2 12BH7A x 2
Rectify: 6x4WA x 2
Channel: 2-Channel Stereo (Discrete L-Channel/R-Channel)
Input Terminals: 4-Input, RCA Terminal (Phono/CD/Tuner/Line)
(* Phono terminal is Flat same as other three. No RIAA circuit built-in)
Output Terminals: 3 RCA Terminals
Input Level Control: Individual L/R volume Control
Main Level Control: L/R volume Control
Power Indicator: Switch On to Red (Muting) gradually change to Green to Ready (Time interval 40-Sec)
Gain: 17dB (Volume Max)
Fix Input Level:
Input: 0.2Vrms
Output: 0.5Vrms (Main Volume Max)
Frequency Response: 5Hz - 100kHz
Noise Level: -84dBm/48.9uVrms (IHF-A)
Cross talk:
Better than 100dB (1 kHz)
Better than 90dB (20 kHz)
Body Construction: All High Quality Aluminum (Front Chassis: 10mm/ Body Chassis: 5mm)
Power Consumption: 45W
Power Requirements: AC 117V or 220-230V, 50/60Hz
Whole Unit Size: 430(W) x 139.5(H) x 411(D) mm (Include feet, screw)
Weight: 14.0kgs
Accessory: Not included (AC Power Cord not included)
We suggest Harmonix X-DC Studio Master Power Cord.
wendigo
