Remton 383 mk2 tube phono stage
Deleted member 38719
κατάσταση 10/10.
Suitable for MM and MC phono cartridges
  • Passive RIAA equalization
  • Zero negative feedback
  • Low noise
  • Gold plated Input/output terminals
  • Soft-start DC high voltage supply
  • Hand picked high quality components
  • Toroidal power transformer
  • Frequency response RIAA: 20 Hz to 20 kHz ±0.5 dB
  • Input impedance: from 36 Ohm to 100 kOhm
  • Input capacitance: 0, 47 pF, 100 pF, 147 pF, 220 pF, 267 pF, 367 pF
  • Output impedance: 0,6 kOhms
  • Gain: MM: 53dB, MC high: 73dB, MC low: 79dB
  • Tube complement matched 3xJJ ECC83S
  • Dimensions: 386 x 295 x 85 mm
  • Weight: 4 kg
Είναι η τελευταία version με τη θωράκιση σε Μ/Σ τροφοδοσίας και στα stepup
seos
