Rimac Automobili
m1ts0s
News poster
"Even primitive (DC) electric motors can outperform any combustion engine in almost all fields. Efficiency, extremely fast response, wide power band, compact size, regenerative braking, high torque... Those are just some advantages of our new permanent magnet synchronous motor generation which we developed exclusively for the Concept_One.
Our unique powertrain is divided into four sub-systems, each consisting of one motor, inverter and reduction gearbox. Each of those systems drives one wheel, completely independent one from the other. Sophisticated ECUs control each of those systems using the input of many precise sensors placed all over the car. This architecture allows a new approach to vehicle dynamics. We call it - All Wheel Torque Vectoring (AWTV).
Each wheel can independently accelerate or decelerate hundreds of times per second, helping to achieve the desired (driver selectable) handling. Together with the very low center of gravity, extremely high torque available almost from zero RPM and the lack of shift interruptions, the Concept_One delivers a completely new driving experience."
"With a curb weight of 1950 kg, and 1088 HP, the Concept_One can reach 100 km/h from standstill in 2.8 seconds and continues to accelerate over 300 km/h."
"One of the most innovative features of the Concept_One is the Rimac All Wheel Torque Vectoring System (R-AWTV), which distributes the power to each single wheel in every situation based on various input factors.
This system gives the Concept_One unique handling characteristics which can be adjusted by the driver. The driver can choose between a neutral and safe (understeer oriented) setup. Alternatively, if the driver has more skills and confidence, an oversteer setup can be chosen. This feature is not only a technological gimmick, it also improves safety since electric motors can react much faster compared to traditional stability control systems (ESP) which are using hydraulic brakes in order to influence the vehicle stability."
Performance
  • Power output: 1088 hp
  • Torque: 1600 Nm from 0 to 6500 rpm
  • Acceleration: 0-100 km/h (0-62 mph) 2,8 seconds
  • Braking distance: 31.5m (100-0 km/h)
  • Lateral g-force: 1.4 g
  • 22 kW on-board charging
  • DC-Combo fast charging (up to 120 kW)
  • Weight-to-power ratio: 1.79 kg/hp
  • Weight distribution: 42% front, 58% rear
Battery-Pack
  • Voltage: 650V nominal
  • Capacity: 82 kWh
  • Liquid cooling
  • Milled aluminum and sheet aluminum housing
  • Rimac Automobili Battery and Thermal Management Systems
  • Several layers of redundant safety and protection systems
Chassis
  • Cro-Mo space-frame with aluminum and carbon-fibre semi-stressed members
  • Front and rear suspension: Double wishbones, fully adjustable, pushrod operated
  • Electronically adjustable ride height
Propulsion System
  • Rear: Rimac Automobili D-PM-OC-600 – high speed dual permanent magnet oil cooled motors, 600 kW peak, 10.000 RPM, up to 97% efficiency
  • Front: Rimac Automobili D-PM-OC-400 - high speed dual permanent magnet oil cooled motors, 400 kW peak, 10.000 RPM, up to 97% efficiency
  • Rotor and stator oil cooling
  • Milled aluminum housings
Steering
  • Rack and pinion electrically power assisted steering.
Brakes
  • Front brakes: Ventilated ceramic discs Ø 390 mm, 36 mm wide.
  • 6-piston calipers, power-assisted.
  • Rear brakes: Ventilated ceramic discs Ø 380 mm, 34 mm wide.
  • 4-piston calipers, power-assisted.
  • Up to 400 kW of regen-braking (adjustable)
Safety Systems
  • ABS
  • Torque Vectoring with stability function
  • Safety disconnect systems in case of crash
  • Multiple ECU architecture for monitoring of safety-relevant electronic systems
Body
  • Full carbon-fibre body
http://www.rimac-automobili.com/
Performance
Battery-Pack
  • Capacity: 82 kWh
  • Liquid cooling
Chassis
Propulsion System
Steering
Brakes
Safety Systems
  • ABS
Body
ΠΡΩΤΗ ΦΟΡΑ ΑΚΟΥΩ ΚΑΤΙ ΤΟΣΟ ΝΕΟ.
ΑΥΤΟΝΟΜΙΑ ΔΕΝ ΛΕΕΙ ΒΕΒΑΙΑ......
ΩΡΑΙΟ ΒΕΒΑΙΑ ΚΑΙ ΤΡΟΜΕΡΑ ΔΥΝΑΤΟ.
ΑΡΑΓΕ ΘΑ ΒΓΕΙ ΣΤΗΝ ΠΑΡΑΓΩΓΗ ΠΟΤΕ?
ΘΑ ΜΠΟΡΟΥΣΕ ΝΑ ΕΞΑΓΟΡΑΣΤΕΙ ΑΠΟ ΤΗΝ ΦΕΡΡΑΡΙ ΚΑΘΟΤΙ ΕΙΝΑΙ ΠΛΕΟΝ Η ΜΟΝΑΔΙΚΗ ΕΤΑΙΡΕΙΑ ΠΟΥ
ΔΕΝ ΕΧΕΙ ΔΕΙΞΕΙ ΤΙΠΟΤΑ ΣΤΟΝ ΤΟΜΕΑ ΑΥΤΟ.
Athanasios1962
