Rip a blu ray with the ps3
Δεν το εχω δοκιμασει.Απλα το αναφερω :109:
C*** has released an incredibly useful application for the PS3 using the OtherOS Open Platform concept. PS3 Swiss Army Knife (SAK), appropriately titled, provides a web interface that enables the following:
* Check Blu-Ray Disk size
* Format internal PS3 HDD
* Back-up iSO to internal PS3 HDD
* Back-up iSO to external EXT3 HDD
* Back-up iSO via wired network, to Windows Network Share
* Explore HDD (Linux side), and download files to a PC.
* Explore Blu-Ray Disks, and download files to a PC (with UDF 2.5 Support!)
* Reboot console
* Reboot console to PS3 GameOS
* Poweroff console
Note: With SAK v1.00 you can now dump your PS3/Blu-Ray disc images without installing PS3 Linux, however, you must still format the PS3 HDD prior (as if you were going to install PS3 Linux) in order to install/use the OtherOS– this is a $ony requirement unfortunately.
How to install: using a memory or USB stick, or CD-R, etc… Copy “otheros.bld” (included in the RAR archive) & “otheros.self” (see below) to “/PS3/OTHEROS/”. Insert your removable media and from the XMB (Settings -> System Settings) run “Install Other OS.” Set the default boot to OtherOS, reboot, and you should be good to go.
http://rapidshare.com/files/133021502/PS3_sak.zip.html all the files are here
Ναι ναι και αν ολα πανε μια χαρα πες να δοκιμασω και εγω γιατι σε κατι τετοια ειμαι και πολυ ....... chicken :137:
opanamas
