ROLAND Drum-machines που έχουν αφήσει εποχή
ROLAND CR-78 CompuRhythm
The CR-78 is a really great little box from Roland. It's a classic analog Rhythm Machine, not a drum machine, and was the first to use a microprocessor. It has 34 built in preset rhythm patterns which can be varied at the push of a button. These patterns include Rock, Disco, Waltz, Shuffle, Slow Rock, Swing, Fox Trot, Tango, etc... Some are cool, but the ability to vary them gives you some creative control.
As for the drum sounds, the CR-78 offers 14 very electronic yet analog drum tones. Sounds include Kick, Snare, Rim, Cow Bell, HiHats, Cymbals, Congas, Bongos, Tambourine and Guiros. With 11 variation effects and the ability to adjust Tempo, accents, and fade in/outs the CR-78 is still capable of producing nice rhythms for use in ambient, HipHop, dub, and other electronic forms of music.
The CR-78 could also be programmed using the standard TS-1 Memory Write Switch or the rather hard-to-find WS-1 programming switch. They allow for pattern programming via a step-programming method similar to that on the TR-808. You program 2 bar patterns one voice at a time and up to 4 voices can be simultaneously played. Each of the four voices can be independently muted from the front-panel allowing for building up and breaking down your rhythm patterns. Patterns can also be set to fade-in/out. User patterns are stored to battery-backed memory.
The CR-78 also has external trigger using 24ppq V-Trig clock pulse. It has a very unique and familiar sound that has been used in all forms of HipHop, R&B and electronica, whether sampled and processed or straight out of the box itself. It's used by Underworld, Fatboy Slim, BT, Gary Numan, 808 State, Phil Collins, Peter Gabriel, Hall & Oates, Ultravox, Jimmy Edgar, Genesis and Uberzone, Blondie, Brian Ferry, Men Without Hats, John Foxx, OMD, and many others.
Κλασσικότερο κομμάτι είναι του Phil Collins και η εισαγωγή του "in the air tonight"
http://www.vintagesynth.org/audio/cr78.ram
ROLAND TR-606 Drumatix
A cool little box! So primitive and cute! The 606 was the percussion side-kick to the TB-303. It even looks like the 303. It stores up to 32 patterns and 8 songs. The 606 allows switching between Pattern Play and Write mode while running - making the 606 the only drumcomputer in the X0X series that can be edited while performing and switching patterns. It is also possible to link up to 4 consecutive patterns in Pattern Play mode. There is only a mono audio output, however there are mods from Kenton Electronics and Analog Solutions that will add individual outputs for each drum tone.
The 606 has seven analog drum sounds which are simple, yet great! Kick, Snare, 2 toms, open hat, closed hat, cymbal, accent. The hi-hats are a very tinny electronic sound and its toms are great for soft tribal patterns. These seven sounds alone are still quite popular today, and the 606 has been used by Uberzone, Cirrus, Sneaker Pimps, Download, Aphex Twin, Astral Projection, Nine Inch Nails, Mr. Oizo, Jimi Tenor, Kid 606, OMD, Moby, Freddy Fresh, Autechre, Luke Vibert, and Union Jack.
http://www.vintagesynth.org/audio/606.ram
ROLAND TR-707 Rhythm Composer
A very underrated drum machine! It resembles the popular TR-909, and better yet, its hi-hat, cymbals, and clap sound almost identical to the TR-909! The TR-707 is a great source for cheap 909 samples. It has some other cool features too such as its Matrix display which clearly maps out your pattern for you in an easy to read display panel. It also features both MIDI in/out and DIN sync control - the best of both worlds. Why this unit even has individual outputs for each of its drum tones!
For programming, it features a shuffle and flam effect and its programming abilities are very impressive. But it does have its limitations, the only adjustment you can make to each drum tone is volume. And all of its other drum tones are boring (especially ride, kick and snare). It's used by Aphex Twin, Laurent Garnier, Squarepusher, Luke Vibert, Freddy Fresh, Phil Collins, Marshall Jefferson and Plastikman.
http://www.vintagesynth.org/audio/707.ram
ROLAND TR-808 Rhythm Composer
The TR-808 is a classic drum machine that used analog synthesis to create its sounds. The sounds have a very thin and pure quality and aren't grungy like it's successor the TR-909. In fact, the 808 has become the signature beatbox used in most R&B and hip-hop as well as a lot of dance and techno music. Booming bass kicks, crispy snares and that annoying cowbell sound made famous during the 80's are all part of the 808 and its famous sound.
Its 16 drum sounds include the famous boomy low kick, snappy snares, low/mid/hi toms, low/mid/hi congas, rimshot, claves, hand clap, maracas, cowbell, cymbal, open hihat, closed hihat and accent. All of the sounds can be edited and/or tuned and have individual outputs. Unfortunately it is not MIDI equipped but it does use Roland's DIN Sync.
The TR-808 was OK in its time. It just didn't sound like real drums. When the Linn Drum machines appeared, the 808 seemed doomed. But its unique sound and analog allure have found it a long-lasting home in many forms of music. Clearly the 808 has been one of the more important and famous drum machines in the history of music, spawning imitators (ReBirth, DrumStation) and band names (808 State). Famous users include Orbital, Uberzone, Download, Aphex Twin, 808 State, BT, Bomb The Bass, Sense Datum, The Prodigy, Josh Wink, Faithless, Skinny Puppy, Bushflange, Jimi Tenor, A Guy Called Gerald, Eat Static, Dr. Dre, Jimmy Edgar, Freddy Fresh, Richie Hawtin, Jean Michel Jarre, Cocteau Twins, Marvin Gaye, Luke Vibert, Ice Cube and Puff Daddy.
http://www.vintagesynth.org/audio/808.ram
ROLAND TR-909 Rhythm Composer
The TR-909 is an awesome analog drum machine! THE standard House and Techno beatbox. Sounds include kick, snare, hand clap, open and closed hi hats, low mid and hi toms, rim shot, ride and crash cymbals. Sounds are tweakable - attack, tone, tuning, decay, snap and accent. This machine does not sound like true acoustic drums, and we don't want it to. It has a unique and very loveable analog sound that's all its own!
Extremely popular today, especially for dance, it is used by 808 State, Air, Bushflange, Future Sound of London, Moby, Norman Cook (Fatboy Slim), Orbital, Hardfloor, Uberzone, Underworld, The Prodigy, Faithless, ATB, Eat Static, Jimmy Edgar, Sense Datum, Richie Hawtin, A Guy Called Gerald, Astral Projection, Josh Wink, Freddy Fresh, Jean-Michel Jarre, Luke Vibert, the Chemical Brothers, and many more! It is armed with Roland's DIN Sync and MIDI, individual outputs, external memory cartridges, and an essential shuffle & flam for great grooves. Use it as a sound module or program patterns, songs and beats into it...either way you'll be in analog drum heaven with the 909!
http://www.vintagesynth.org/audio/heavy909.ram
http://www.vintagesynth.org/audio/909.ram
xfader
Μπράβο Dream! Πολύ καλό post.
Πράγματι η Roland έφτιαξε το όνομα της με τα drum machines της , που όλα πια θεωρούνται classic.
Εγώ είχα πολύ παλιά ένα TR-808 και είχα φάει ατέλειωτες ώρες κατασκευάζοντας ρυθμικά patterns.
Τα τελευταία χρόνια τα vintage αυτά drum machines έχουν κάνει comeback στη hip hop και R&B μουσική και είναι υπεύθυνα για αρκετά hits.
Το καλό πια είναι ότι οι ήχοι των ROM τους έχουν κυκλοφορήσει σε wave αρχεία και μπορεί ο καθένας να τους χρησιμοποιήσει χωρίς να έχει το original μηχάνημα.
Αλέξανδρε, Ναι πολλά ευτυχώς τα έχουμε σε Βιβλιοθήκες και έτσι τους ήχους τους μπορούμε να τους αναπαράγουμε, όμως η χάρη της χρήσης των αναλογικών αυτών μηχανημάτων δεν συγκρίνεται... κάτι σαν την μίξη με τα πλατώ ΜΚΙΙ και Numark... ένα ταίρι που δεν ξαναβρίσκεις στον ψηφιακό κόσμο...!!
Πάρε μερικά δέιγματα απο τα 505 και 303 της ROLAND, να δείς DANCE BAND-in-a-box, άκου τα (ra) samples που έχουν.
ROLAND MC-505 Groovebox
An all in one techno music production studio, this machine has it all. A massive collection of professional and coveted electronic synth and drum sounds, effects, built-in real-time VCF and envelope knobs for tweaking, a sequencer/arranger, and many other great additions. This is the successor to the MC-303 and is now much more advanced. Its sounds will be familiar to any techno-head.
The LFO and resonant filters allow quick and easy sound manipulation. The new D-Beam allows you to randomly tweak your sounds by passing your hand over a laser beam! It has a great sequencer for building your songs (with groove quantizing and part level faders for mixing) as well as many idea catchers like the phrase sampler and arpeggiator.
This is an all-in-one music machine that's great for DJ's or anybody else who wants to create slamming dance tracks. Designed as a stand alone machine, they do not work quite as well when incorporated into a multi-synth keyboard rig. It's perfect for beginners and advanced users, but offers the most possibility to those who will use it exclusively. By the way, in comparison to the MC-303, this is far better especially in the quality and quantity of sounds! It is used by Beck, Chicks On Speed, Peaches, Freddy Fresh, and Cibo Matto.
http://www.vintagesynth.org/audio/mc505.ram
ROLAND MC-303 Groovebox
The original groovebox for dance/techno! It's got 303, 808, 909, Jupiter, and Juno sounds. It is a sequencer arranger and looks a lot like the original 303's and 808's... Not to mention it includes real-time Filter Cutoff, resonance, panning and arpeggiator. With this box alone you can become a techno music maker!!! It sounds pretty good and has an unbeatable price (around $500)!!!! Though it's been swept aside by the MC-505, JX-305, EG-101 and Yamaha RM1x, it's still a good entry-level machine for those of you on a budget or just starting out. It has been used by ATB.
http://www.vintagesynth.org/audio/mc3033.ram
http://www.vintagesynth.org/audio/mc3031.ram
seos
